Mmm.. as proved, my ignorance is great, and probably my english is poor too.
I'm sorry Greg but I didn't understand the following:
" .A long-standing bug has been recently pointed out by Zack Rogers
.related to the orientation of full photometric distributions, and has
.been included in the latest HEAD available from radiance-online.org.
.A statement has also been added to clarify the assignment of the
.width (along y) and length (along x) axes. "
What are HEADs in radiance-online.org ?
And actually it is not orientation of photometric distribution the thing which is wrong, but just the luminaire shape which is rotated.. (due to ies2tab and not to ies2rad). But I could be wrong...
Lucio
.Hope this helps.
.-Greg
.> From: "loscotec\@libero\.it" <loscotec@libero.it>
.> Date: February 6, 2008 6:28:49 AM PST
.> Hi everybody !
.> I've got a problem I'm not sure how to deal with.
.> I'm using a Disano light to simulate a tunnel lighting. It is a
.> fluorescent light.
.> I converted it to radiance format from ies format (previously
.> translated from eulumdat format) using ies2rad with no specific
.> value. Then I calculated illuminance on road surface visualizing
.> isolux scheme.
.> Then I converted the same light with the "-t white" option. And
.> calculated illuminance's isolux as before.
.> The two isolux schemes are different, being value for the white
.> case almost 10 % bigger.
.> Shouldn't them be equal?
.> I tried simulating same case in dialux and calculux, and they do
.> report almost same values as the white case.
.> What's wrong? Am I missing some knowledge / trick / anything?
.> Lucio
.> Ps : I also discovered some problems both in ies2tab and in
.> eulumcnv. The second, badly converting photometry (some dark
.> circles appear in the lighted scene as missing photometric values),
.> the first badly converting geometry (flipping x and y definitions).
.> But I have to check this things a little more.
._______________________________________________
.Radiance-general mailing list
.Radiance-general@radiance-online.org
.http://www.radiance-online.org/mailman/listinfo/radiance-general
