Thank you for your comments. As only radiance(W/m2sr) or irradiance(W/m2)
values are being dealt with from modeling to results lamp color does not
make problem as Lars said and radiance value also has no problem as 0.032m
is diameter, which Lars might already know. But the aging of lamps might
need to be checked, that means all the conditions of experiment should be
checked again as the experiment was done at the field, in case there is no
problem in RADIANCE calculation.
Sung
Message: 3
Date: Mon, 16 Mar 2009 16:30:30 +0800
Subject: Re: [Radiance-general] I can't get even similar irradiance
values from a lamp.
Content-Type: text/plain; charset="iso-2022-jp"
Hi!
irradiance level on the surfaces of the box. The cylindrical lamps
has 32mm in diameter and 540mm in length and The radiance of 44W/sr/
m2 calculated with the UV output of the lamps (7.5W) was applied to
the lamps.
Hm, how did you calculate the 44W/sr/m2 for the lamps? I get
7.5/(2*pi*0.54*0.032)=7.5/0.1086=69W/m2, divided by pi=21.99 W/m2sr.
This means that your light source is two times brighter than I would
expect it to be.
CU Lars.
Type: text/x-vcard
Desc: not available
Url :
http://radiance-online.org/pipermail/radiance-general/attachments/20090316/f
17a5681/lars_grobe-0001.vcf
Message: 4
Date: Mon, 16 Mar 2009 13:41:45 +0000
Subject: ReE: [Radiance-general] I can't get even similar
irradiancevalues from a lamp.
To: <[email protected]>
Content-Type: text/plain; charset="gb2312"
Also, I'm curious how you'd use LAMPCOLOR for a UV-lamp? Obviously the
efficacy would not be the usual 179?
YC Huang
Message: 5
Date: Mon, 16 Mar 2009 22:51:48 +0800
Content-Type: text/plain; charset=GB2312
Well, it is probably not. But if you multiply the 7.5W to get the lumen
output, lampcolor will internally divide by 179 to calculate back to
radiometric values, so the result should be fine (as long as you do not
start to multiply the results of rtrace to get anything like lux or nits
from what is not visible light )...
One nice problem if comparing the result to experimental measurements
will be that the lamp's age will probably show some influence on the
real output. So most probably something like 7.5W*0.9 or 0.8 would be
more realistic. But I have NO experience with this UV stuff, so this is
something to find out first.
CU Lars.
End of Radiance-general Digest, Vol 61, Issue 12
