How to use trad
Hi everyone,
I am learning Radiance recently and when I follow the radiance_tutorial to use the following command.
trad
it shows the following error, does anyone know how to install trad.
Kind regards,
Hao
$ trad
Command ‘trad’ not found, did you mean:
command ‘trax’ from snap trax (1.0)
command ‘tpad’ from snap tpad (2.1)
command ‘tracd’ from deb trac (1.5.3+dfsg-1)
command ‘tran’ from deb tran (5-3)
command ‘tred’ from deb graphviz (2.42.2-6)
See ‘snap info ’ for additional versions.
You must install the latest version of Tcl/Tk on your system, then run “rmake install” from the ray/src/util directory to install trad, if it will install at all on your computer.
Thank you so much for your reply. I followed your suggestion and it works. I appreciate your assistance.
Moreover, I wanted to express my admiration for Radiance; it is truly an outstanding software.
Warm regards,
Hao
