How to parse room dimensions from .rad model ?
Crossing over to the general list...
If you can create an octree from your model, try the command and option getinfo -d
That will return the dimensional information for your full scene though, so if there are objects included outside of your area of interest, it becomes more tricky.
Sent: Friday, February 07, 2014 12:12 PM
To: radiance-dev
Subject: [Radiance-dev] How to parse room dimensions from .rad model ?
Hello everyone,
It is a kind of weird question but thought to hear your views.
Let's say, someone gave me a .rad file which is a model of a rectangle room. This model has many polygons for surfaces such as walls, windows, luminaire, furniture etc.
How shall I develop a method/function that can parse this .rad file and return me back the room dimensions. I have no additional information, like walls' name variable etc.
I want to make a simple java method for that. I am not using any CAD API.
Is it possible? Please don't bash me for my stupid question.. :stuck_out_tongue:
Best regards,
Vaib
Yes, let's keep this on the general mailing list. The dev list is primarily for development/debugging issues.
The getbbox command will give you a tight box (right rectangular prism) on the entire scene, whereas oconv will report an enclosing cube. However, this won't help you much if your space is non-rectangular or not axis-aligned.
A general tool for extracting the walls from a room is technically the 3-D convex hull problem. There are programs out there to compute this, but I haven't played with them.
Date: February 7, 2014 9:41:21 AM PST
Crossing over to the general list…
If you can create an octree from your model, try the command and option getinfo –d
To: radiance-dev
Hello everyone,
Best regards,
Vaib
getbbox will solve the issue at hand. Rooms/scenes are mostly right
rectangular prism; and also they are normally kept aligned with principal
axes, only the sky (if with sun) is rotated to change the North. I guess,
to rotate the sky instead of the scene must be preferred for modeling
architectural scenes in Radiance.
Further, just out of curiosity: getinfo -d foo.oct gives [Xmin, Ymin, Zmin,
Size] of the bounding cube (I guess cuboid too?). I couldn't figure what
does Size mean? Is it Xmax or Y/Zmax?
Thank you for your time!
Best regards,
Vaib
axis-aligned.
*Date: *February 7, 2014 9:41:21 AM PST
getinfo -d
*Sent:* Friday, February 07, 2014 12:12 PM
*To:* radiance-dev
*Subject:* [Radiance-dev] How to parse room dimensions from .rad model ?
Hello everyone,
Best regards,
Vaib
The size returned by "getinfo -d octree" is the cube side length, which is of course the same in all three dimensions.
Date: February 12, 2014 2:08:22 PM PST
getbbox will solve the issue at hand. Rooms/scenes are mostly right rectangular prism; and also they are normally kept aligned with principal axes, only the sky (if with sun) is rotated to change the North. I guess, to rotate the sky instead of the scene must be preferred for modeling architectural scenes in Radiance.
Further, just out of curiosity: getinfo -d foo.oct gives [Xmin, Ymin, Zmin, Size] of the bounding cube (I guess cuboid too?). I couldn't figure what does Size mean? Is it Xmax or Y/Zmax?
Best regards,
Vaib
Thank you Dr.Greg. It makes sense now.
I am just curious to know your opinion on changing the site's North by
rotating the Sky. Do you think it is a good practice? Because on rotating
the building/room, one cannot take full advantage of other good programs
such as getbbox and/or getinfo -d.
*Date: *February 12, 2014 2:08:22 PM PST
Best regards,
Vaib
axis-aligned.
Thank you Rob! :slight_smile:
Vaib
On 12 February 2014 23:44, Guglielmetti, Robert < [email protected]> wrote:
Hi Vaib,
Yes, that's generally how folks do it with Radiance, is rotate the sky to
mimic an off-axis building footprint. It's done for the reasons you cite,
as well as for efficiency in the octree. There are a few posts on this on
the archives.
- Googs
From: Vaib <[email protected]<mailto:[email protected]>>
Reply-To: Radiance discussion <[email protected]
Date: Wednesday, February 12, 2014 at 3:34 PM
To: Radiance discussion <[email protected]<mailto:
[email protected]>>
Subject: Re: [Radiance-general] How to parse room dimensions from .rad
model ?
On 12 February 2014 23:18, Greg Ward <[email protected]<mailto: > [email protected]>> wrote:
Best regards,
Vaib
On 7 February 2014 18:47, Greg Ward <[email protected]<mailto: > [email protected]>> wrote:
axis-aligned.
[email protected]>
