How to consider weather condition for daylight simulation in Radiance
Hi everyone,
I recently learned to use Radiance for interior daylight simulation. I read the first 6 chapters of Rendering with Radiance (1998), but there is no clear introduction to consider weather conditions for daylight simulation.
I have read the topic related to the weather before (weather data in radiance - #3 by Lars_Grobe). But I am still confused with the following aspects:
  1. Can I assume that when the gensky is used to generate the sun and the sky, it already considers the weather conditions? Because the irradiance database that gensky used to define the sky and sun, already considers weather conditions (the equipment to record the irradiance is on the ground so the data it recorded considers the influence of different weather)
  2. For daylight simulation, should we distinguish the weather conditions and atmosphere conditions.
  3. My understanding of GENDAYLIT is that it mainly considers different atmosphere conditions which my already considered when the sun data was recorded.
Thank you in advance for your help.
Best regards,
Hao
Hi @Hao,
When we talk about “weather” in the context of Radiance simulations, we are usually talking about the level of cloudiness (absorption and diffusion) in the atmosphere. We do not consider other factors like rain. So for our purposes, weather and atmosphere are the same.
The GENSKY program produces clear, overcast, and intermediate skies according the their CIE definitions. This is useful if you want to render a space under sunny conditions (e.g., for shadow visualization or glare simulation) or overcast conditions (e.g., for daylight factor calculation).
The GENDAYLIT program produces skies according to the Perez All-Weather Sky Model. This is useful if you want to match the recorded direct and diffuse components from TMY weather data files.
Hey Hao,
On point 3, you mentioned atmospheric conditions. gendaylit does not directly model atmospheric parameters such as precipitable water vapor or aerosols. Instead, it focuses on generating sky, sun, and ground irradiance (or illuminance) based on the provided direct and diffuse irradiance components (DNI and DHI). These irradiance components inherently account for the effects of atmospheric conditions, such as cloud cover, scattering, and absorption.
Additionally, it’s important to distinguish between Typical Meteorological Year (TMY) data and weather data. TMY provides a representative year of meteorological data. In contrast, weather refers to actual measurements of meteorological parameters taken during specific periods.
Both will be accepted by gendaylit and the choice depends on the purpose of your study.
Alex
Note:
If you want to have better control over atmospheric conditions you can check genssky. However, I have not yet experimented with it.
Hi @Nathaniel_Jones and @Funerus,
Thank you so much for your explanation which gives me a clearer understanding of the function of Radiance. I will learn the gendaylit and genssky programs and the TMY data. I truly appreciate it.
However, I am still confused about the following point: when the data of the sun was recorded, the data already includes the atmospheric condition (the equipment to record the irradiance is on the ground ). So when the gensky command uses this sun data to generate the sun and sky, it already considers the atmospheric conditions. So why should consider the atmospheric condition again? I don’t have much experience in daylight analysis, so this question might seem foolish.
Or the solar data is from the satellite, so when the gensky is used to generate sun and sky, with defaults (its default is clear CIE sky, ), the radiance data of solar is the data in the perfect atmospheric condition(without cloud); for the sky distribution, the -t 2.450000 # Atmospheric turbidity is used to give sky daylight distribution and determines the diffuse horizontal irradiance.
Best regards,
Hao
Hi @Hao,
The measurement equipment is located at ground level. However, the measurement equipment only records global horizontal irradiance and direct normal irradiance (or, more likely, it records other data and uses algorithms to calculate GHI and DNI). However, GHI and DNI do not provide enough information to generate the sky distribution that Radiance needs. Instead, you must provide additional information to describe how the diffuse irradiance is distributed across the sky dome.
If you use GENSKY, then you will specify a CIE sky type that determines the distribution, and you may optionally specify turbidity directly to modify the distribution away from the standard. If you use GENDAYLIT, then the distribution is produced according to the Perez model based on the direct and diffuse components and solar angle.
A minor correction – the turbidity in gensky does not affect the sky distribution, only the calculated zenith brightness. The CIE models are designed to be simple for reproducibility that way.
Therefore, there is no need to specify the turbidity if you know the diffuse irradiance or zenith radiance, as those specifications override the default calculation. This is in fact the recommended way to use gensky if you have measurements.
Hi @Nathaniel_Jones ,
Thank you very much for your reply.
Your explanation is very helpful. I will learn the corresponding concepts and background knowledge to gain a deep understanding of how to deal with weather conditions.
Best regards,
Hao
Hi @Greg_Ward,
Thank you so much for your correction. That is very helpful.
Currently, I don’t have any measurements. I plan to use TMY data as the weather condition. Then set a day having 7 different weather conditions. For each weather condition, simulate the interior lighting condition of a room. In this case, could you please give me some suggestions for the program I can use? Or the GENDAYLIT and the Gendaylit are good choices?
Best regards,
Hao
I would definitely recommend gendaylit over gensky if you are attempting to simulate different weather conditions, because that’s what gendaylit’s Perez sky model is designed to do. The CIE sky model is more intended to create reproducible comparisons between designs under “typical” skies, and gensky does not contain any of the more advanced CIE intermediate sky types.
Thanks a lot for your recommendation and helpful explanation. I will explore gendaylit and the Perez sky model as you suggested.
By the way, for the standard to introduce the CIE sky models, is the standard BS ISO 15469: Spatial distribution of daylight — CIE standard general sky?
Hao
Hi @Nathaniel_Jones,
When I compared the gensky and gendaylit, I found that there is a big difference between the solar radiance. For the same time selected from the TMY data of a site, I used gensky and gendaylit as following commands:
 gensky 1 1 10.5 -y 2014 +s -a -27.47 -o -153.05 -m -150
 gendaylit -ang 71.1 -99.1 -W 939 148
The output of the visible radiance are as follows:
void light solar
3 7.151e+06 7.151e+06 7.151e+06
For the gendaylit, the visible radiance is
void light solar
3 7.979e+06 7.979e+06 7.979e+06
I think that the reason for the difference are from two aspects:
  1. The default settings of atmospherical turbidity are different: for gensky the -t (# Atmospheric turbidity) is 2.45 and for gendaylit the -t (# Atmospheric betaturbidity) is -0.1;
  2. The models they use are different: genskt produces a CIE standard sky distribution and gendaylit uses Perez model.
Am I right?
Thank you for your help.
Best regards,
Hao
Hi @Hao,
Your reason #2 is correct, but your method is wrong. The gensky program is not intended for TMY data because it assumes an idealized clear sky, whereas the TMY data comes from measurements under real (non-idealized) conditions. Basically, you gave gensky input that does not match its internal model, and now you are wondering why it gave you the wrong output.
Hi Hao,
Actually, I’m surprised the difference between gensky and gendaylit isn’t greater, as they use different solar radiance estimates.
I feel like I’m repeating myself, but as I have said, unless you specify the direct and indirect solar values via the -b, -B, -r, or -R options, you are effectively telling gensky to guess at the daylight levels. (Similarly, gendaylit has the -W, -G, -L, and -E options if you don’t like its guesswork.)
The turbidity in this case does not influence the solar radiance. It is only used in gensky to adjust the zenith brightness, and as @Nathaniel_Jones says, it uses the CIE clear sky model by default rather than the Perez all-weather model. If you specify the diffuse levels with gensky -b or -B, then the turbidity factor is not used at all.
While gendaylit has an option for the “beta turbidity,” which is not the same as “turbidity,” it does not actually use this value anywhere in its code – I checked. As I did not write this tool, I am not sure if it was used at one time or not. In any case, turbidity and beta turbidity are not comparable. Turbidity must have a value of 1.0 or greater, whereas beta turbidity values tend to be lower. I do not think it is ever negative – the default value in gendaylit is “-t 0.1” not “-0.1”.
I hope this helps.
Hi @Nathaniel_Jones
I think that my previous description is unclear. So sorry for that. I chose the time 10:30 a.m. on 1st January 2014 and used the gensky to generate the corresponding sky and sun. Then for the TMY data, I chose the DNI and DHI of the same date as input to gendaylit to generate the corresponding sky and sun to compare these two commands.
However, based on your and @Greg_Ward’s reply, I understand that gensky was just based on the option I gave to guess the daylight level and generate a CIE standard sky distribution. If I want to use TMY data as input of gensky, I should use -B DHI to determine sky distribution and -R horizontal direct irradiance to generate the sun radiance.
However, as you reply, the gensky is not intended for TMY data and these two commands use different models, they are not comparable.
Thank you so much for your reply and explanation. I truly appreciate it.
Happy New Year in advance.
Best regards,
Hao
Hi @Greg_Ward,
Thank you so much for your patience and through explanation.
Afther reading your explanation, I revisited the manpages of these two commands and the related sections in the Rendering with Radiance. Your insights have provided me with a much deeper understanding of these two commands and daylight analysis. I truly appreciate your guidance and I apologize for making you repeat the answer – I’ve been stuck on this topic for some time.
Besides, you are right. The default value in gendaylit is “-t 0.1. I am sorry for the typo.
Once again, I sincerely thank you for your patient and detailed explanation.
Wishing you a Happy New Year in advance and I hope you have a wondeful time.
Best regards,
Hao
