How to calculate the ( rtn gtn btn ) values of the material type glass ?
I don't know how I didn't thought about this. It seems also like quite
an intuituve description!
The results also look like right.
Nevertheless I define how I have proceeded, because there is a step that
could be wrong.
From the hole transmitance spectrum of each glass sample I have just
taken the transmittance values at this wavelengths you said and then
calculated its tn
#glass sample 01
Rot=700nm Tn=40.8 rtn= 18.093
Green=546 Tn=48.13 gtn= 18.813
Blue=436 Tn=42.87 btn= 18.317
void glass smpl_01
3 0.18093 0.18813 0.18317
And this would be the hole material description of this transparent
glass, als just one layer glass, 10mm thick
Thanks again,
Marina
Hi Marina,
The tn formula assumes your Tn values are between 0 and 1, not 0 and 100% -- your results should be:
void glass smpl_01
3 0.4449 0.5248 0.4675
Good that you checked!
From: marina aviles olmos <marina.aviles@gmail.com>
Date: March 17, 2009 9:02:44 AM PDT
could be wrong.
calculated its tn
#glass sample 01
void glass smpl_01
Thanks again,
Marina
