From: Philip Schwarz <philip.johann.schwarz@googlemail.com>
Date: April 6, 2018 3:46:14 AM PDT
I am seeing the following error again, even after adding the src/px/tiff directory:
https://gist.github.com/philipjss/bded331695eedfad0e76f48557b21427#file-build-1-console-output-txt-L121-L126
This is how it looks now:
cd tiff; make distclean
make[1]: Entering directory `/home/radiance/src/px/tiff'
make[1]: *** No rule to make target `distclean'. Stop.
make[1]: Leaving directory `/home/radiance/src/px/tiff'
make: *** [clean] Error 2
Should I ignore the error? Is there a way to eliminate it?
Philip Schwarz
On 5 April 2018 at 19:43, Philip Schwarz <philip.johann.schwarz@googlemail.com> wrote:
@Greg
Yes, I can confirm that if I download the Radiance overlay (Auxiliary files) and take the src/px/tiff directory, and add it to the radiance 5.0 codebase that I am trying to build, the following errors go away:
make clean error
Lib tiff error
https://gist.github.com/philipjss/bded331695eedfad0e76f48557b21427#file-build-1-console-output-txt-L599-L610
make: Target `install' not remade because of errors.
https://gist.github.com/philipjss/bded331695eedfad0e76f48557b21427#file-build-1-console-output-txt-L672
That leaves me with the following:
Cannot find wish executable in current path -- trad not installed.
https://gist.github.com/philipjss/bded331695eedfad0e76f48557b21427#file-build-1-console-output-txt-L802-L803
There were some errors.
https://gist.github.com/philipjss/bded331695eedfad0e76f48557b21427#file-build-1-console-output-txt-L827
You have explained why the first is happening, and the second is just a message which would not appear if the first error wasn't there.
Thanks for that. Great.
The Radiance overlay (Auxiliary files) are 380MB (unzipped) - the src/px/tiff directory within them is 8-9MB.
As you pointed out in another email, I am using a very stripped down version of Linux. amazonlinux 2017.09 is 165MB.
We want it to be as small as possible to keep down the cost and time it takes to create deploy and run our application in a docker container on AWS.
Right now, we are going to start off wanting to run just oconv and rtrace. In time, we may run more commands.
On that basis, adding all of the Radiance overlay to our application seems prohibitive.
Is there something that conveys how Radiance's various binaries rely on which part of the Radiance overlay?
E.g. you said that if we can do without ra_tiff then we don't need src/px/tiff - by the way, what is ra_tiff? I don't think I can see it among the binaries created by the build.
Can oconv and rtrace run without ra_tiff?
Does the idea of running without the Radiance overlay make any sense, e.g. if wanting to run just oconv and rtrace?
What is the set of binaries that can happily run without Radiance overlay? Are oconv and rtrace among them? If not, what portions of the Radiance overlay do they rely on?
Is it possible to pick and choose, within reason, which parts of the Radiance overlay are needed based on the binaries one wishes to run?
Any help would be greatly appreciated.
Philip
On 5 April 2018 at 18:01, Gregory J. Ward <gregoryjward@gmail.com> wrote:
After installing "ed", you would need to remove the unedited Version.c file to recreate it with makeall.
Regarding your other errors, you need to install the Radiance overlay (Auxiliary files) that includes the src/px/tiff directory (I think). The link was on the downloads page:
https://www.radiance-online.org/download-install/radiance-source-code/un-official-head-version
This is also responsible for the distclean error. You can just ignore the errors related to libtiff and do without ra_tiff in your distro.
To run trad, you need to install wish. If you don't have it, you can't use that program, so it doesn't bother installing.
Date: April 5, 2018 9:19:57 AM PDT
now that I no longer get X11-related compilation errors, I am down to the following 5:
make clean error
Lib tiff error
I would really appreciate it if you could have a quick look.
Is there a quick fix for them?
If not, how serious are they?
Thank you for your help.
Philip
Radiance-dev mailing list
https://www.radiance-online.org/mailman/listinfo/radiance-dev
