We have installed Radiance in a new computer and we have been checking if it works. When I try to run falsecolor the system says that helvet.fnt is not found. Nevertheless, that file is in the RAYPATH and we don’t know what can be the problem.
Could you help us?
Irene
Hi Irene,
It looks like there is a typo in your Raypath. Starting it with “./” indicates that the path is relative to your current directory, when you probably meant to provide an absolute path starting with “/”.
Nathaniel
Thank you so much Nathaniel.
I have changed what you said and now it works perfectly.
Irene
