help pfilt and low values dgp
Somehow cant use the command pfilt or change the pcomb, does this has to do
with the program Radiance? I have installed the version of windows from the
site, with evalglare v1.11windows . The problem is that I have composed a
.hdr (out of 7 jpg on a mac) and after using the command c:/HDRI>evalglare
-vth -vh 140 -vv 80 image.hdr all the dgp results are really low, less than
5%. The problem can be in the .hdr (calibrated as well) or is in the way
evalglare is not working as it shoot on my computer.
*.hdr file* (post-it is calibration point 167,98)
*images* original
*command printscreen*
Need the help!
Greetings Jacobus
*Jasper Overduin*
MSc Building Technology graduate student at Delft University of Technology
*S* Groenhoevelaan 3
*P* 2343 BP Oegstgeest
*T* +31 6 15 64 48 56 (NL)
*T* +56 9 51 11 76 48 (CL)
*E *[email protected]
*Skype *jasper.overduin
Hi Jasper,
why are you using -vth -vh 140 -vv 80 when in your header of the HDR image the view is specified as -vtv -vh 98.797409 -vv 75.402067 ?
Manipulating the lense type is really dangerous - in that case you change from a perspective view to a hemispherical fish eye view, without changing the image!!
If I apply evalglare for your image I get 0.17 as DGP (which is still very low, but you have only 2000cd/m2 as maximum value, so this can be expected). Be aware, that DGP accounts only for glare from a high amount of daylight and/or spots of extreme luminances (>50000cd/m2), but not for contrasted glare between task (e.g. Monitor) and immediate surroundings for lower adaptation levels. This is subject of current research (also here at EPFL) and there might be an extension of the DGP in future, depending on the outcome of new experiments.
Back to the lens-type:
It is extremely important, that the right view type is given to evalglare, otherwise ALL calculated values (it doesn't matter if this is evalglare or findglare) are wrong. These errors could be huge, more than 100% for calculating the illuminance out of a 180 degree image.
If you manipulate an image by pcomb, in general the view is marked as "invalid" in the header, because with that tool you could manipulate the image in a way, that the original view is not valid any more. This is why from evalglare version 1.0 on a check on the header was included, because many people were creating wrong headers without knowing it and then evalglare was calculating wrong values, when the header was invalid.
In addition for calculating the DGP it is important to have the illuminance at camera level. evalglare calculates this value out of the image. But if the image does not cover 180 degree, then the calculated value for the illuminance is too low. For that reason, the -i option was included, so you can provide the illuminance to evalglare (when you measure it with an illuminance sensor).
So in your case, you should measure the illuminance just besides the lens.
Then (in case this is the right lens description) you should use
evalglare -i LUXVALUE -vtv -vh 98.797409 -vv 75.402067 IMAGE_NAME
or better, if your task is always at the same place:
evalglare -i LUXVALUE -vtv -vh 98.797409 -vv 75.402067 -T 395 230 .6 -c CHECK_FILE_PICTURE IMAGE_NAME
good luck!
Jan
Am 4/30/15 um 6:04 PM schrieb Jasper Overduin:
Somehow cant use the command pfilt or change the pcomb, does this has to do with the program Radiance? I have installed the version of windows from the site, with evalglare v1.11windows . The problem is that I have composed a .hdr (out of 7 jpg on a mac) and after using the command c:/HDRI>evalglare -vth -vh 140 -vv 80 image.hdr all the dgp results are really low, less than 5%. The problem can be in the .hdr (calibrated as well) or is in the way evalglare is not working as it shoot on my computer.
*.hdr file* (post-it is calibration point 167,98) Dropbox - Error - Simplify your life
*images* original Dropbox - Error - Simplify your life
*command printscreen* Dropbox - Error - Simplify your life
Need the help!
Greetings Jacobus
*Jasper Overduin*
MSc Building Technology graduate student at Delft University of Technology*
*P*2343 BP Oegstgeest
*E *[email protected] <mailto:[email protected]>
Dr.-Ing. Jan Wienold
EPFL ENAC IA LIPID
LE 1 111 (Office)
Phone +41 21 69 30849
Thank you for the fast reply. We are still having some problems with the
outcome of Evalglare. With an external luxometre we have done some tests
now. The DGP is still very low or zero. It seems that in almost all the
case the DGP is low. In literature we read that values above 20% are
normal. What do you think? is the data much better if we use a full 180
degree lens?
.hdr file Dropbox - Error - Simplify your life
print screen cmd
test.pic Dropbox - Error - Simplify your life
Greetings Jasper
*Jasper Overduin*
On 30 April 2015 at 13:55, Jan Wienold <[email protected]> wrote:
Hi Jasper,
the image!!
lens.
good luck!
Jan
*images* original
Need the help!
Greetings Jacobus
*Jasper Overduin*
Radiance-general mailing [email protected]://www.radiance-online.org/mailman/listinfo/radiance-general
EPFL ENAC IA LIPID
LE 1 111 (Office)
Hi Jasper,
I briefly looked at your image - for sure you get a low DGP value if your illuminance at camera (or eye) level is only about 300lux... It is not the matter of the fish eye lens it is a matter of your lighting condition.
When I remember correctly, for the experiments I did for my PhD, the people adjusted the blinds in a way, that they had 2500-3000 lux at the eye level and they were less than 20% of them dissatisfied. So a value of 300 means one order of magnitude less light at the eye level and a much lower adaptation level.
So I definitely understand the low DGP value in that case. The images themselves look reasonable, so I don't think there is a problem in calibration/processing so far (at least not for these low luminance levels-it might be more tricky to calibrate for the high luminance values when you get stray-light from the multiple lenses).
If all your images are like that it means you have a very low daylight contribution at the place you measure. I'm not sure if DGP is then the right way to measure glare in that case - as I wrote it is made more for the daylight oriented workplace with higher levels and also to take into account very high luminances (e.g. sun or specular reflections of the sun). DGP might be modified in future, but these experiments are just starting.
Jan
Am 4/30/15 um 10:41 PM schrieb Jasper Overduin:
    with the outcome of Evalglare. With an external luxometre we have
    done some tests now. The DGP is still very low or zero. It seems
    that in almost all the case the DGP is low. In literature we read
    that values above 20% are normal. What do you think? is the data
    much better if we use a full 180 degree lens?
print screen cmd Dropbox - Error - Simplify your life
    Greetings Jasper
    *Jasper Overduin*
    Technology*
    On 30 April 2015 at 13:55, Jan Wienold <[email protected] > <mailto:[email protected]>> wrote:
        Hi Jasper,
        75.402067 ?
        besides the lens.
        good luck!
        Jan
        *images* original
        Need the help!
        Greetings Jacobus
        *Jasper Overduin*
        of Technology*
        -- Dr.-Ing. Jan Wienold
        EPFL ENAC IA LIPID
        LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
Dear all,
I have changed my lens to one with 180 circular view to do a contrast
analysis (hdrscope) and meanwhile the glare analysis in evalglare. If i use
the commands in evalglare getinfo i get the (HDR composed with photosphere
on a mac, calibrated with luminance pistol) i get a value for the lens -vv
and -vh which is not over 100, with a lens of 180. I can imagine that the
photo ratio and the lens are not the same and that causes this problem. But
when I enter the external measured Ev, the value the dgp goes somehow to
zero. The fact that the gdp is zero with a maximum luminance of 5600 cd/m2
and Ev of 2500 lux makes me a bit suspicious. How accurate is the result of
the dgp without external vertical lux? is it possible to use this value?
hdr files and printscreens of evalglare
https://www.dropbox.com/sh/ei1y4d2v6hapdsr/AACgVMPd1o0EdK-0q8CFvUGga?dl=0
Greetings Jasper
*Jasper Overduin*
MSc. Building Technology graduate student at Delft University of Technology
On 1 May 2015 at 12:15, Jan Wienold <[email protected]> wrote:
Hi Jasper,
adaptation level.
Jan
degree lens?
print screen cmd
Greetings Jasper
*Jasper Overduin*
Hi Jasper,
lens.
good luck!
Jan
*images* original
Need the help!
Greetings Jacobus
*Jasper Overduin*
Technology
EPFL ENAC IA LIPID
LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
Hi Jasper,
This is one of the tricky aspects of doing glare analysis with your own HDR images. A couple of pointers are below,
  * You will need to crop your image to a square aspect about the image
    center using the pcompos
    <http://radsite.lbl.gov/radiance/man_html/pcompos.1.html&gt; tool.
    There was a helpful discussion on maintaining image exposure values
    while doing this here
    <http://www.radiance-online.org/pipermail/radiance-general/2011-March/007701.html&gt;\.
  * The -vv and -vh parameters are just best guesses according the HDR
    generation software. Once you have cropped the image, you will want
    to open the resulting HDR in a text editor and manually change the
    header 'VIEW' field to include -vta -vv 180 -vh 180. You may also
    specify them via the command line at this point, as you have done. I
    like to keep it associated with the image.
  * After that, unless I am forgetting something (others can chime in),
    you are ready to run evalglare. I would run it with the -d flag,
    which will report a lot of details. Most usefully, it reports
    illuminance as derived from the image, which you can compare to your
    measured Ev value to check the validity of the HDR. If your HDR is
    well-calibrated, not inputting the measured illuminance value should
    be perfectly accurate.
  * I suspect that inputting measured illuminance is somewhat broken in
    the current version of evalglare as I have the same problem that you
    do. One option is to use the -1 option to evalglare, which will
    return only a single DGP value. It seems to avoid this error.
     > evalglare -1 -i 2500 image.hdr
By the way, to avoid some of this cropping and exposure value pain, I use an image-processing tool (like PIL for Python) these days that can maintain EXIF data while cropping the source jpeg files. Though perhaps the cure is worse than the disease in this case..
Alstan
On 8/11/2015 11:08 PM, Jasper Overduin wrote:
Dear all,
I have changed my lens to one with 180 circular view to do a contrast analysis (hdrscope) and meanwhile the glare analysis in evalglare. If i use the commands in evalglare getinfo i get the (HDR composed with photosphere on a mac, calibrated with luminance pistol) i get a value for the lens -vv and -vh which is not over 100, with a lens of 180. I can imagine that the photo ratio and the lens are not the same and that causes this problem. But when I enter the external measured Ev, the value the dgp goes somehow to zero. The fact that the gdp is zero with a maximum luminance of 5600 cd/m2 and Ev of 2500 lux makes me a bit suspicious. How accurate is the result of the dgp without external vertical lux? is it possible to use this value?
hdr files and printscreens of evalglare Dropbox - Error - Simplify your life
Greetings Jasper
*Jasper Overduin*
On 1 May 2015 at 12:15, Jan Wienold <[email protected] > <mailto:[email protected]>> wrote:
    Hi Jasper,
    lenses).
    Jan
        problems with the outcome of Evalglare. With an external
        luxometre we have done some tests now. The DGP is still very
        low or zero. It seems that in almost all the case the DGP is
        low. In literature we read that values above 20% are normal.
        180 degree lens?
    print screen cmd
        Greetings Jasper
        *Jasper Overduin*
        of Technology*
        On 30 April 2015 at 13:55, Jan Wienold <[email protected] >> <mailto:[email protected]>> wrote:
            Hi Jasper,
            experiments.
            sensor).
            besides the lens.
            should use
            IMAGE_NAME
            good luck!
            Jan
            my computer.
            *images* original
            Need the help!
            Greetings Jacobus
            *Jasper Overduin*
            EPFL ENAC IA LIPID
            LE 1 111 (Office)
    EPFL ENAC IA LIPID
    LE 1 111 (Office)
Hi Jasper,
hi Alstan,
I guess there are several issues in that case. First of all, as Alstan wrote, you should crop the image and provide the correct lens specification to evalglare. Be aware that editing the header could be dangerous, because sometimes editors add strange characters or you don't see tabs in the header with marks the view string there as "invalid" . In case the header is interpreted "wrong" in evalglare, the results could be really random and could differ for more than 100% from the right ones (e.g. the calculation of the vertical illuminance, see presentation on the Radiance workshop in 2012). The header treatment is much more robust since the evalglare version 1.08, but still the user should take care of providing a correct header. evalglare is relying on a correct radiance header. To be on the safe side, you should always use the command option to provide the correct view option to evalglare.
Also you should make sure, that you use a view type which really corresponds to your lens. If your real lens is a hemispherical fish eye and you provide -vta as view string, the angles and solid angles are calculated wrong in evalglare and you get wrong results. So make sure that you use -vta only if your lens is a angular fish eye.
And please don't use the -1 option in evalglare!!! This is a special (undocumented) option to get fast results on images calculated without ambient calculations. If you use it for normal images, the glare sources might not detected correctly and you could get big differences. It is working mostly properly in images with large black areas (-ab 0).
Since the -1 option is not robust for normal images, this option is undocumented. There exist also other undocumented options since 2009 for hdr treatment(e.g. pixel overflow correction, image fillup when ccd-array is smaller than the projected image...), but these options are by purpose undocumented because they should be used only in special cases and can cause wrong results when not used properly.
If I look at your image, I guess your calibration is not correct. The sun has a luminance of 2e10 cd/m2. In case of low transmittance glazing you still have a luminance of Xe9 cd/m2, lets say at least 1e9cd/m2, which is factor 200000 higher than you measured!!! And be aware you you might have to deal with blooming effects when you have a pixel overflow (especially when looking into the sun). Not sure about your camera setting, but if you still have an overflow for the shortest exposure, you should think of adding a neutral grey filter to reduce the overall transmittance to the ccd.
Finally I can't reproduce the 0 output of evalglare. I used your image and used as well the 2500lux as input (even if the image is not cropped correctly and the view string is wrong). See here:
/evalglare -i 2500 pmar_sin_03.hdr//
//Notice: Low brightness scene. Vertical illuminance less than 380 lux! dgp might underestimate glare sources//
//dgp,dgi,ugr,vcp,cgi,Lveil: 0.311778 18.132195 21.670120 44.798004 27.925421 58.052605 //
/But I always get an non-0 result, I never experienced this before. I tried the linux ,the mac and also the windows version with your image - it didn't happen. So which version are you using? Which operating system? (type evalglare -v to find out)
@Alstan: Can you provide me another example where this happens as well? Which version are you using? Which operating system?
A zero value should never appear, except your image is completely black.
Jan
Am 8/11/15 um 5:33 PM schrieb J. Alstan Jakubiec:
Hi Jasper,
    image center using the pcompos
    values while doing this here
    want to open the resulting HDR in a text editor and manually
    change the header 'VIEW' field to include -vta -vv 180 -vh 180.
    You may also specify them via the command line at this point, as
    you have done. I like to keep it associated with the image.
    in), you are ready to run evalglare. I would run it with the -d
    flag, which will report a lot of details. Most usefully, it
    reports illuminance as derived from the image, which you can
    compare to your measured Ev value to check the validity of the
    HDR. If your HDR is well-calibrated, not inputting the measured
    illuminance value should be perfectly accurate.
    in the current version of evalglare as I have the same problem
    that you do. One option is to use the -1 option to evalglare,
    which will return only a single DGP value. It seems to avoid this
    error.
Alstan
Dear all,
Greetings Jasper
*Jasper Overduin*
On 1 May 2015 at 12:15, Jan Wienold <[email protected] >> <mailto:[email protected]>> wrote:
    Hi Jasper,
    lenses).
    Jan
        180 degree lens?
    print screen cmd
        Greetings Jasper
        *Jasper Overduin*
        of Technology*
        On 30 April 2015 at 13:55, Jan Wienold <[email protected] >>> <mailto:[email protected]>> wrote:
            Hi Jasper,
            experiments.
            sensor).
            besides the lens.
            should use
            IMAGE_NAME
            good luck!
            Jan
            on my computer.
            *images* original
            Need the help!
            Greetings Jacobus
            *Jasper Overduin*
            EPFL ENAC IA LIPID
            LE 1 111 (Office)
    EPFL ENAC IA LIPID
    LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
Hi Jasper and Alstan,
I just found this in the revision-logging of the evalglare source code(it is such a long time ago that I could not remember...) :
/* evalglare.c, v1.11 2013/01/17 wienold
    - fix output bug of dgp, when using -i or -I
are you using an older version of evalglare than v1.11 which is from January 2013??
best,
Jan
Hi Jasper,
    error.
Alstan
Dear all,
Greetings Jasper
*Jasper Overduin*
    Hi Jasper,
    lenses).
    Jan
        180 degree lens?
    print screen cmd
        Greetings Jasper
        *Jasper Overduin*
        of Technology*
            Hi Jasper,
            experiments.
            sensor).
            besides the lens.
            should use
            IMAGE_NAME
            good luck!
            Jan
            on my computer.
            *images* original
            Need the help!
            Greetings Jacobus
            *Jasper Overduin*
            EPFL ENAC IA LIPID
            LE 1 111 (Office)
    EPFL ENAC IA LIPID
    LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
Hi Jan,
Apologies for the -1 comment -- I didn't know it did anything special beyond only returning DGP.
As for the version of evalglare, I was using v1.10 -- Doh! I installed Daysim last week to get the source for Linux, and it put an old version in my path. The 0 result issue doesn't happen with version 1.11. Probably the Daysim installer should be updated at some point.
     > /Also you should make sure, that you use a view type which really
    So make sure that you use -vta only if your lens is a angular fish eye./
I can also second this. I ended up with an equi-solid fisheye lens, and there is no small amount of effort converting the images into a -vta type for Radiance use.
Alstan
On 8/12/2015 5:39 PM, Jan Wienold wrote:
Hi Jasper,
hi Alstan,
Jan
Hi Jasper,
    HDR generation software. Once you have cropped the image, you
    will want to open the resulting HDR in a text editor and manually
    error.
Alstan
Dear all,
Greetings Jasper
*Jasper Overduin*
On 1 May 2015 at 12:15, Jan Wienold <[email protected] >>> <mailto:[email protected]>> wrote:
    Hi Jasper,
    multiple lenses).
    Jan
        very low or zero. It seems that in almost all the case the
    print screen cmd
        Greetings Jasper
        *Jasper Overduin*
        On 30 April 2015 at 13:55, Jan Wienold >>>> <[email protected]> wrote:
            Hi Jasper,
            should use
            IMAGE_NAME
            good luck!
            Jan
            *images* original
            Need the help!
            Greetings Jacobus
            *Jasper Overduin*
            EPFL ENAC IA LIPID
            LE 1 111 (Office)
    EPFL ENAC IA LIPID
    LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
Im using evalglare 1.10 release 30.09.2012 with windows 7
The photos are calibrated with a (il)lumination pistol with 4 different
measurements (with maximum deviation of 0.4 cd/m2)
There is a certain coating on the window, not sure what kind. but as you
said the difference is huge.
Within the program of HDRscope there is a similar function and gives and
errer as well if i use an external Ev value.
Greetings,
Jasper
*Jasper Overduin*
On 12 August 2015 at 06:39, Jan Wienold <[email protected]> wrote:
Hi Jasper,
hi Alstan,
to evalglare.
*evalglare -i 2500 pmar_sin_03.hdr*
*Notice: Low brightness scene. Vertical illuminance less than 380 lux! dgp
might underestimate glare sources*
*dgp,dgi,ugr,vcp,cgi,Lveil: 0.311778 18.132195 21.670120 44.798004
27.925421 58.052605 *
Jan
Hi Jasper,
   - You will need to crop your image to a square aspect about the image
   <http://radsite.lbl.gov/radiance/man_html/pcompos.1.html&gt; tool. There
   was a helpful discussion on maintaining image exposure values while doing
   this here
   - The -vv and -vh parameters are just best guesses according the HDR
   generation software. Once you have cropped the image, you will want to open
   the resulting HDR in a text editor and manually change the header 'VIEW'
   field to include -vta -vv 180 -vh 180. You may also specify them via
   the command line at this point, as you have done. I like to keep it
   - After that, unless I am forgetting something (others can chime in),
   you are ready to run evalglare. I would run it with the -d flag, which
   will report a lot of details. Most usefully, it reports illuminance as
   derived from the image, which you can compare to your measured Ev value to
   check the validity of the HDR. If your HDR is well-calibrated, not
   inputting the measured illuminance value should be perfectly accurate.
   - I suspect that inputting measured illuminance is somewhat broken in
   the current version of evalglare as I have the same problem that you do.
   One option is to use the -1 option to evalglare, which will return
Alstan
Dear all,
<Dropbox - Error - Simplify your life;
Greetings Jasper
*Jasper Overduin*
*E * <[email protected]>[email protected]
Hi Jasper,
adaptation level.
Jan
degree lens?
print screen cmd
Greetings Jasper
*Jasper Overduin*
Technology
On 30 April 2015 at 13:55, Jan Wienold < <[email protected]> >>> [email protected]> wrote:
Hi Jasper,
lens.
good luck!
Jan
*images* original
Need the help!
Greetings Jacobus
*Jasper Overduin*
Technology
EPFL ENAC IA LIPID
LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
Hi Jasper,
you definitely should use a newer version of evalglare.
If you go to the website:
http://www.ise.fraunhofer.de/radiance
you can at least download the 1.11 version-which doesn't have this bug.
The will be a new version of evalglare coming out in the next days/weeks (version 1.17) - this will be announced separately here in that group.
Regarding your image: Your calibration must span the luminance-range you want to measure.
If you calibrate between 1cd/m2-1000 cd/m2 it does not tell you anything how accurate you are when measuring 100000cd/m2!
So if you want to measure the luminance of the sun, then you have to make sure your camera is calibrated for such high luminances as well.
I guess when you want to measure several million cd/m2 you might need a grey filter. At ISE we had several filters down to 0.0001 transmittance, so it was easy to measure also towards the sun and the increase of noise for the lower luminaces doesn't hurt so much.
Your coating on the window play a minor role in that case... honestly for the sun you can be lucky to measure with one or 2 orders of magnitude, so if your glazing is 0.75 or 0.4 in light transmittance is negligible compared to the difference between 5000 and 200000000 cd/m2 !
The picture you have in dropbox is also difficult to check with an illuminance meter when you integrate the values to an illuminance value, because the sun is so much on the side and has a very flat angle of incidence to your measuring plane. For example when your angle of incidence for the light source (here sun) is 80� and your "uncertainty" for putting the sensor in the right plane wold be 2.5 degree (it is very difficult to put it more accurate), then you have automatically an uncertainty in your sensor reading of 25% (of the illuminance)! (because illuminance is cos-weighted and a difference in angle for large angles is big for the cosinus).
Good luck!
best,
Jan
Am 8/12/15 um 3:21 PM schrieb Jasper Overduin:
The photos are calibrated with a (il)lumination pistol with 4 different measurements (with maximum deviation of 0.4 cd/m2)
There is a certain coating on the window, not sure what kind. but as you said the difference is huge.
Within the program of HDRscope there is a similar function and gives and errer as well if i use an external Ev value.
Greetings,
Jasper
*Jasper Overduin*
On 12 August 2015 at 06:39, Jan Wienold <[email protected] > <mailto:[email protected]>> wrote:
    Hi Jasper,
    hi Alstan,
    evalglare.
    angular fish eye.
    used properly.
    black.
    Jan
    Hi Jasper,
        tool. There was a helpful discussion on maintaining image
        exposure values while doing this here
        the HDR generation software. Once you have cropped the image,
        you will want to open the resulting HDR in a text editor and
        manually change the header 'VIEW' field to include -vta -vv
        180 -vh 180. You may also specify them via the command line
        at this point, as you have done. I like to keep it associated
        with the image.
        chime in), you are ready to run evalglare. I would run it
        with the -d flag, which will report a lot of details. Most
        usefully, it reports illuminance as derived from the image,
        which you can compare to your measured Ev value to check the
        accurate.
        broken in the current version of evalglare as I have the same
        problem that you do. One option is to use the -1 option to
        evalglare, which will return only a single DGP value. It
    case..
    Alstan
    Dear all,
    Greetings Jasper
    *Jasper Overduin*
    Technology
        Hi Jasper,
        adaptation level.
        Jan
            external luxometre we have done some tests now. The DGP
            the case the DGP is low. In literature we read that
            data much better if we use a full 180 degree lens?
        print screen cmd
        test.pic
            Greetings Jasper
            *Jasper Overduin*
            On 30 April 2015 at 13:55, Jan Wienold >>>> <[email protected] <mailto:[email protected]>> wrote:
                Hi Jasper,
                image!!
                you should use
                IMAGE_NAME
                good luck!
                Jan
                *images* original
                Need the help!
                Greetings Jacobus
                *Jasper Overduin*
                EPFL ENAC IA LIPID
                LE 1 111 (Office)
        EPFL ENAC IA LIPID
        LE 1 111 (Office)
    EPFL ENAC IA LIPID
    LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
Thanks a lot for the help so far. I've updated the evalglare to 1.11.
Getting the same results as Jan showed.
I've desinstalled and reinstalled everything, and now the pcompos and other
functions are not recognized. With a google search I couldnt find the
problem.
any ideas?
installed
radiance 2.01
daysim 4.0
ecotect 2011
evalglare 1.11
As far as the picture. This is the only photo with an almost direct sun.
Other photos (160) are within a more sober spectrum. The idea is to to an
analysis of cd/m2 ratios, with the evalglare as indicator, not as main
target. Do you think it is possible to use the data?
Greetings,
Jasper
*Jasper Overduin*
On 13 August 2015 at 11:23, Jan Wienold <[email protected]> wrote:
Hi Jasper,
want to measure.
for the light source (here sun) is 80° and your "uncertainty" for putting
cosinus).
Good luck!
best,
Jan
Greetings,
Jasper
*Jasper Overduin*
Hi Jasper,
hi Alstan,
to evalglare.
dgp might underestimate glare sources*
Jan
Hi Jasper,
   this here
   which will report a lot of details. Most usefully, it reports illuminance
   as derived from the image, which you can compare to your measured Ev value
   to check the validity of the HDR. If your HDR is well-calibrated, not
Alstan
Dear all,
Greetings Jasper
*Jasper Overduin*
Technology
On 1 May 2015 at 12:15, Jan Wienold < <[email protected]> >> [email protected]> wrote:
Hi Jasper,
adaptation level.
Jan
degree lens?
.hdr file <Dropbox - Error - Simplify your life;
print screen cmd
test.pic <Dropbox - Error - Simplify your life;
Greetings Jasper
*Jasper Overduin*
Technology
On 30 April 2015 at 13:55, Jan Wienold < <[email protected]> >>>> [email protected]> wrote:
Hi Jasper,
lens.
good luck!
Jan
*images* original
Need the help!
Greetings Jacobus
*Jasper Overduin*
Technology
EPFL ENAC IA LIPID
LE 1 111 (Office)
<[email protected]>
<http://www.radiance-online.org/mailman/listinfo/radiance-general&gt;
EPFL ENAC IA LIPID
LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
