[help] error message from running gencumulativesky
Dear Radiance experts,
I got a long list of error message in the terminal when running
gencumulativesky.exe in Win7
Error! Solar altitude < 6 degrees and Idh > 10 W/m^2 on day 1! Attempting
to continue!
to continue!
Error! Solar altitude < 6 degrees and Idh > 10 W/m^2 on day 2! Attempting
to continue!
Error! Solar altitude < 6 degrees and Idh > 10 W/m^2 on day 3! Attempting
to continue!
Error! Solar altitude < 6 degrees and Idh > 10 W/m^2 on day 347!
Attempting to continue!
Error! Solar altitude < 6 degrees and Idh > 10 W/m^2 on day 349!
Error! Solar altitude < 6 degrees and Idh > 10 W/m^2 on day 359!
Error! Solar altitude < 6 degrees and Idh > 10 W/m^2 on day 364!
There were 4064 sun up hours in this climate file
Total Ibh/Lhb: 661.221506
The gencumulativesky command is:
gencumulativesky +s2 -a 51.15 -o -0.18 -m 0 -h -2 -G
./London_weather_file_global_and_diffuse_radiation.txt >
CumulativeSky_df_London.cal
The "London_weather_file_global_and_diffuse_radiation.txt" used contains two
columns of data extracted from London's epw file that are "global horizontal
radiation" and "diffuse horizontal radiation" for every hour of the whole
year.
The CumulativeSky_df_London.cal and a SunFile.rad files were generated. And
the SunFile.rad file contains 2165 sun position definitions.
May I ask:
1. Am I running the GenCumulativeSky.exe correctly?
2. What does the error message mean? and Why is the error generated?
3. Will the error affect the two files generated?
Thanks in advance!
- Ji
to continue!
May I ask:
If those are the only errors I expect that you do.
I haven't used GenCumulativeSky but from what I remember from the discussion
of this tool GenCumulativeSky uses gendaylit to create sky models. Gendaylit
has difficulties with low sky angles and doesn't create useful sky
descriptions for these times of day. There is only one or two errors per day
so I assume the errors happen for early morning or late evening (altitude <
6 degree). To solve this error properly we need a better gendaylit program.
I would expect that these entries in your climate file are simply not
represented in the the cumulative sky model. A way to work around this might
be to hack gencumulativesky to provide gendaylit with explicit sun positions
and artificially increase the altitude to be above 6 degree.
On Sat, Jul 23, 2011 at 8:03 AM, Ji Zhang <[email protected]> wrote:
