HDRI Digest, Vol 48, Issue 1
Hi Greg and Axel,
Thank you so much for your input. Both methods seem to work although I'm still a bit confused on the ASA setting.
Greg, in your comment:
Usually the only information missing is the ASA, and this can usually be solved by choosing an ASA that is 1 EV higher.
Do you have an example you might be able to offer that I can work from? I'm not sure how to work out an ASA from an exposure value. Would the ASA value change with each bracketed exposure? I'm still scratching my brain cells around some of this and am not sure yet how to interrupt sensor sensitivity from these Machine Video cameras and the various settings the interface allows one to control.
Thanks again!
Chris
Send HDRI mailing list submissions to
than "Re: Contents of HDRI digest..."
Today's Topics:
  1. adding EXIF headers to JPEGS (Humann Chris)
  2. Re: adding EXIF headers to JPEGS (Axel Jacobs)
  3. Re: adding EXIF headers to JPEGS (Gregory J. Ward)
Message: 1
Date: Fri, 20 Apr 2012 15:13:31 -0700
Subject: [HDRI] adding EXIF headers to JPEGS
Content-Type: text/plain; charset="us-ascii"; Format="flowed";
  DelSp="yes"
Dear Group,
I'm using an Industrial video camera to capture exposure bracketed JPG
stills that I'd like to turn into HDR images. The problem that I'm
having is that HDRgen and Photosphere both throw an error:
from HDRgen=
phdrimg.cpp@560>data: fc2_save_2012-04-20-202102-0000.jpg: needs
exposure calibration
or from Photoshpere=
Inkown image exposure(s)
using Exiftool I've tried writing to the header in each JPG like so:
exiftool -ExposureTime='1/5' image_1.jpg
However I continue to get the same exposure errors. Is there more
that I need to add into the Header? Below is the header printed from
exiftool for a sample JPG taken by the camer:
<!-- image_1.jpg -->
<table>
<tr><td>ExifTool Version Number</td><td>8.88</td></tr>
<tr><td>File Name</td><td>fc2_save_2012-04-20-202102-0000.jpg</td></>
<tr><td>Directory</td><td>.</td></tr>
<tr><td>File Size</td><td>637 kB</td></tr>
<tr><td>File Modification Date/Time</td><td>2012:04:20 14:48:31-07:00</
></tr>
<tr><td>File Permissions</td><td>rwxr-----</td></tr>
<tr><td>File Type</td><td>JPEG</td></tr>
<tr><td>MIME Type</td><td>image/jpeg</td></tr>
<tr><td>JFIF Version</td><td>1.01</td></tr>
<tr><td>Exif Byte Order</td><td>Big-endian (Motorola, MM)</td></tr>
<tr><td>X Resolution</td><td>72</td></tr>
<tr><td>Y Resolution</td><td>72</td></tr>
<tr><td>Resolution Unit</td><td>inches</td></tr>
<tr><td>Y Cb Cr Positioning</td><td>Centered</td></tr>
<tr><td>Exposure Time</td><td>1/60</td></tr>
<tr><td>Exif Version</td><td>0230</td></tr>
<tr><td>Components Configuration</td><td>Y, Cb, Cr, -</td></tr>
<tr><td>Flashpix Version</td><td>0100</td></tr>
<tr><td>Color Space</td><td>Uncalibrated</td></tr>
<tr><td>Image Width</td><td>1280</td></tr>
<tr><td>Image Height</td><td>960</td></tr>
<tr><td>Encoding Process</td><td>Baseline DCT, Huffman coding</td></>
<tr><td>Bits Per Sample</td><td>8</td></tr>
<tr><td>Color Components</td><td>3</td></tr>
<tr><td>Y Cb Cr Sub Sampling</td><td>YCbCr4:2:0 (2 2)</td></tr>
<tr><td>Shutter Speed</td><td>1/60</td></tr>
<tr><td>Image Size</td><td>1280x960</td></tr>
</table>
As always thanks for any info or help.
Kind regards,
Chris
Christian Humann ~ Associate
LOISOS + UBBELOHDE
Alameda, CA 94501 USA
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
URL: <http://www.radiance-online.org/pipermail/hdri/attachments/20120420/34a8674b/attachment-0001.html&gt;
Message: 2
Date: Fri, 20 Apr 2012 23:41:47 +0100
To: High Dynamic Range Imaging <[email protected]>
Subject: Re: [HDRI] adding EXIF headers to JPEGS
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Chris,
However I continue to get the same exposure errors. Is there more that I
hdrgen need the following info:
- ExposureTime
- ISO
- FNumber
If it still fails, try writing the ExposureTime as floating-point
seconds; but I think fractions are fine.
Axel
Message: 3
Date: Fri, 20 Apr 2012 15:56:21 -0700
Content-Type: text/plain; charset=us-ascii
Hi Chris,
You can also substitute the -s option in the case of hdrgen (not Photosphere, though). This sets the exposure multiplier explicitly. You can estimate this from the known camera parameters using:
    Kfactor = 87.;
    stonits = Kfactor * aperture*aperture / (exptime * asa);
where aperture is in f-stops and exptime is in seconds.
That way, you don't need exiftool. Usually the only information missing is the ASA, and this can usually be solved by choosing an ASA that is 1 EV higher.
HDRI mailing list
End of HDRI Digest, Vol 48, Issue 1
LOISOS + UBBELOHDE
510 521 3800 VOICE
510 521 3820 FAX
On Apr 21, 2012, at 12:00 PM, [email protected] wrote:
