Greetings. Is anyone aware of a compiled version of 'hdrgen' that works under Ubuntu? I downloaded Greg's 'Linux' version placing the binaries in the appropriate bin directory but no joy.
Chris
Chris
Hi Chris,
I think you are asking me, as I'm the only one with access to the full source code outside of Dolby... And no, I haven't compiled it under Ubuntu. I haven't compiled under any recent version of Linux in fact. I don't know how cross-compatible binaries are. It's a pain due to all the external library dependencies (OpenEXR and TIFF mostly), but I could try recompiling it on the Lubuntu image I have under VMWare. Can anyone tell me how likely that is to work as an executable?
Date: August 23, 2012 4:04:11 PM PDTGreetings. Is anyone aware of a compiled version of 'hdrgen' that works under Ubuntu? I downloaded Greg's 'Linux' version placing the binaries in the appropriate bin directory but no joy.
Chris
I've been able to compile (or at least run it) using Ubuntu. I believe
the troubles I had earlier were related to a 64bit Ubuntu distro.
Don't know if that's your issue, but I think I ran into that before and
couldn't figure out the specific dependency that was missing (an older
version than what I had available).
Chris
Chris Coulter
Senior Lighting Designer
Buro Happold Consulting Engineers
100 Broadway, 23rd Floor
New York, NY 10005
Tel: 212.334.2025
Direct: 212.616.0254
Email: chris.coulter@burohappold.com
Website: www.burohappold.com
Sent: Thursday, August 23, 2012 7:04 PM
To: hdri@radiance-online.org
Subject: Re: [HDRI] hdrgen on ubuntu
Chris
HDRI mailing list
HDRI@radiance-online.org
Hey Greg,
For whatever it is worth I have had no problems compiling the latest Radiance on the latest Ubuntu (after adding a few extra packages).
I was able to roll a fresh ubuntu using vmware player in a very short amount of time. Not sure of the status of hdrgen at this point, I hope this helps.
the troubles I had earlier were related to a 64bit Ubuntu distro.Don't know if that's your issue, but I think I ran into that before and
version than what I had available).Chris
Chris Coulter
New York, NY 10005
Tel: 212.334.2025
Website: www.burohappold.com-----Original Message-----
Subject: Re: [HDRI] hdrgen on ubuntuGreetings. Is anyone aware of a compiled version of 'hdrgen' that works
in the appropriate bin directory but no joy.Cheers,
Chris_______________________________________________
HDRI mailing list
http://www.radiance-online.org/mailman/listinfo/hdri_______________________________________________
HDRI mailing list
Chaps,
I've recently had the pleasure of rebuilding my 64bit Fedora system from scratch due to a failing hard disk. Got hdrgen working, too.
hdrgen is a 32bit application, so simply doing a
# apt-get install libtiff
on a 64 bit Debian-based system will only pull the 64bit Tiff library. So make sure you have all the 32bit deps on your 64bit system. The two co-exist quite happily.
The only bit of 'hacking' I had to do was to soft-link libtiff.so.4 (what comes with Fedora) to libtiff.so.3 (which is what hdrgen is linked against).
Chris, if you can expand on 'no joy', I might be able to give you a few pointers.
Cheers
Axel
On 08/24/2012 12:17 AM, Gregory J. Ward wrote:
Hi Chris,
HDRI mailing list
I managed to compile hdrgen under Lubuntu using VMWare, so if anyone else wants a copy, let me know. I'll send one to Axel since it's a little more recent version of the code (I think).
Date: August 23, 2012 5:28:50 PM PDTWorks great. Thank you so much Greg!
Best regards,
Chris
Christian Humann ~ Associate
LOISOS + UBBELOHDE
Alameda, CA 94501 USA
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.comOn Aug 23, 2012, at 4:43 PM, Gregory J. Ward wrote:
<hdrgen.gz>
I am going to install hdrgen, can I copy the compiled hdrgen? Thank you very much.
-Jing
At http://anyhere.com/ there are a few versions of hdrgen you can download. We don’t have one for Windows, unfortunately.
