Glazing transparency/reflectivity study
I'm considering doing a study comparing the transparency (as viewed from outside) of two glazing types on a building modeled in radiance. The study would render several viewpoints (and view angles looking up the facade) for the multiple glass types under a variety of sky conditions (sunny, cloudy, etc). The primary goal of the study would be to as follows:
1. Demonstrate how exterior transparency changes with different glass types (with different coatings and exterior reflectances)
2. Demonstrate how exterior transparency changes with angle of incidence
3. Demonstrate how exterior transparency changes based on ratio of interior to exterior illuminance (or more accurately, luminances).
I'm only interested in this as a comparative study: does glass type A look clearer than glass type B when viewed at X angle and under Y sky condition, and Z interior/exterior illuminance ratio.
My question to the list is:
1. Comments on the usefulness of this study?
2. Advantage of using Optics 5 rad file (BRTDfunc) over glass primitive? My understanding is it more accurately captures the color of the glass and reflectivity... anything else?
Galen
Hi Galen,
I won't comment on the usefulness of your proposed study, other than to say it sounds interesting to me... I do have a couple of suggestions, however.
The output of Optics5 should not be used directly, but should be passed through the "optics2rad" script to get the desired angular behavior from the selected glazing. In the case of multi-layer glazing systems, you may be better off using the "glaze" script to define your material. This script does a much better job modeling the multiple reflections that occur in a double-glazed system.
Date: January 14, 2009 2:39:40 PM PST
Galen
Hi Galen,
You should probably consider the glaze script to produce a material description for your glazing. I think that this will you get the most sophisticated description for a glass material. You can incorporate data that is output from Optics for single monolithic glass types to build up double pane insulating units if needed. A coating can be applied to a selected layer of the make-up. Note, that using the simple BRTDfunc description output from Optics (unless this has been updated in the past few years) does not account for variation due to incident angle. There is actually a way to set up the glaze script so it accepts a file of glass types as input rather than using the rather minimal inputs that come with script.
Let me know if you have any questions and I will do the best I can to help out.
Galen
# Jack de Valpine
Hi Galen,
A couple of subtleties to watch out for.
   1. the normals for glass geometry must be uniformly oriented and
      point to the interior of the space
   2. the header spacing if very specific and relies on tabs only as I
      recall
   3. I think that you will also find that the appearance in the images
      will be sensitive to the ambient parameters that are used
Jack de Valpine wrote:
Hi Galen,
No problem.
Regarding the header
    * Rc<r,g,b> - these are the rgb components for the reflectance on
      the "coated" side of the monolithic glass
    * Rg<r,g,b> - these are the rgb components for the reflectance on
      the non-coated side of the monolithic glass
    * T<r,g,b> - these are the rgb components for the transmittance
      for the monolithic glass
    * Part - this is a boolean value
          o 0 means this is a regular glass
          o 1 means this is a frit - if this is the case the "coated"
            side reflectance needs to represent the reflectance of the
            frit at 100% coverage which should be possible to extract
            from the glazing manufacturer
The RGB values are extracted from the file generated for a "radiance" export from Optics. This should be for a single pane monolithic glass description (not a multi-layer make-up). The file will have three Radiance material definitions, the two BRDTfunc definitions are the ones to pay attention to. The makeup is something like the following:
    void BRTDfunc some.glass.front
    10
        Rfr Rfg Rfb
        Tr Tg Tb
        0 0 0
    9 0 0 0 0 0 0 0 0 0
    void BRTDfunc some.glass.back
    10
        Rbr Rbg Rbb
        Tr Tg Tb
        0 0 0
    9 0 0 0 0 0 0 0 0 0
So you need to take the two rgb triples for reflectance and one for transmittance. So an entry in the data file could look like this (you will need to figure which represents the coated side if needed):
    Surface Tr Tg Tb Rcr Rcg Rcb Rgr Rgg Rgb Part
    <name> Tr Tg Tb Rfr Rfg Rfb Rbr Rbg Rbb 0
A file for a double pane insulating unit might look like the following:
    green-lowe Tr Tg Tb Rfr Rfg Rfb Rbr Rbg Rbb 0
The glaze script contains a default "clear" glass. I seem to recall that this is required for the script to output a material description (eg it must have a "clear" glass description"). If this is not suitable the script requires some modification, which I think I can offer some guidance on so that you can include your own "clear" glass description.
I would suggest before you do anything else you should test out the script as is with the built in values. This will let you see how it works. You will assign different materials to different layers to build up the composite unit.
Try it out and let me know if you have more questions.
Jack,
Thanks for the input and offer to answer a few questions. Much appreciated.
I see the header information the glaze script is looking for the following when importing a data file:
Questions:
1. Are the RGB values for T, Rc, Rg easily found in Optics 5? I selected 'Color - Transmittance' under Tools>Select Spectrum, and tried all the different wavelength functions, but I'm not seeing RGB anywhere.
Am I missing something?
2. Between Rc and Rg, which one refers to outside surface?
3. What does 'Part' refer to in the header above?
4. For a double pane IGU with a low-e coating on green glass (surface 2), would the data file look something like this?
1 Trgb, Rrgb, Part information for green glass
2 Trgb, Rrgb, Part information for green glass + LowE coating (or would it be just the LowE coating?)
3 Trgb, Rrgb, Part information for clear glass
4 Trgb, Rrgb, Part information for clear glass
Thanks for your time and assistance - much appreciated.
Galen
Message: 3
Date: Wed, 14 Jan 2009 18:08:02 -0500
Subject: Re: [Radiance-general] Glazing transparency/reflectivity
        study
Hi Galen,
come with script.
help out.
Galen
# Jack de Valpine
URL: http://radiance-online.org/pipermail/radiance-general/attachments/20090114/1769d356/attachment-0001.html
End of Radiance-general Digest, Vol 59, Issue 8
# Jack de Valpine
# Jack de Valpine
Thanks Jack.
All seems clear and I've got some results that I'm pretty happy with. One thing I'm still a little unclear about is how you would apply a low-e film to a non-clear glass (i.e. tinted green, blue, etc) if the script requires one surface to be "clear" for each pane.
For example:
VE2-2M (http://www.viracon.com/makeupsheet.php?id=3840) has the VE-2M coating applied to Evergreen glass on the #2 surface. As it is now, I would input:
Surface 1 - Clear
Surface 2 - VE2-2M on evergreen (from optics 5 data)
Surface 3 - Clear
Surface 4 - Clear
Is there an easy hack to make Surface 1 evergreen instead of clear?
Galen
Date: Thu, 15 Jan 2009 21:07:06 -0500
Subject: [Radiance-general] Re: Radiance-general Digest, Vol 59, Issue
        8
To: Galen Burrell <[email protected]>
Cc: Radiance general discussion <[email protected]>
Hi Galen,
No problem.
    * T<r,g,b> - these are the rgb components for the transmittance for
    10
        Rfr Rfg Rfb
        Tr Tg Tb
        0 0 0
    9 0 0 0 0 0 0 0 0 0
    10
        Rbr Rbg Rbb
        Tr Tg Tb
        0 0 0
    9 0 0 0 0 0 0 0 0 0
I think you just specify surface 1 as evergreen and surface 2 as VE2-2M. The effect is the same as making them the same surface, I think.
Date: January 15, 2009 7:54:09 PM PST
Thanks Jack.
For example:
VE2-2M (http://www.viracon.com/makeupsheet.php?id=3840\) has the VE-2M coating applied to Evergreen glass on the #2 surface. As it is now, I would input:
Surface 1 - Clear
Surface 3 - Clear
Surface 4 - Clear
Galen
Hi Galen,
It has been a while, but I think that the color/tint comes from the rgb values for the coated glass. So the color would be conveyed by "VE2-2M on Evergreen" monolithic export from Optics 5. So this should account for the color of the coated glass. However, I think that I have to defer to Greg on this for confirmation.
Note for Viracon:
    <type><color>-<transmittance>
    so
    type = VE = Low-E
    color = 2 = Green
    transmittance = 2M = ~70%
    if you want "Evergreen" you need to look at color 8.... so VE8-2M
One way to sanity check is to run a single layer output from glaze and specify s1 as clear and s2 as VE2-2M on evergreen. The last three lines of the material description should give you:
    Rext_r Rext_g Rext_b
    Rint_r Rint_g Rint_b
    Tr Tg Tb
The rgb components should be the same as those exported from Optics5 (even though you are specifying "clear" for one layer).
Hope this helps.
Thanks Jack.
For example:
Surface 1 - Clear
Surface 3 - Clear
Surface 4 - Clear
Galen
        8
Hi Galen,
No problem.
    10
        Rfr Rfg Rfb
        Tr Tg Tb
        0 0 0
    9 0 0 0 0 0 0 0 0 0
    10
        Rbr Rbg Rbb
        Tr Tg Tb
        0 0 0
    9 0 0 0 0 0 0 0 0 0
# Jack de Valpine
Yes, well, unfortunately Greg doesn't know what he's talking about, because Galen was right when he said that the glaze script demands one surface be clear glass. Your suggestion is better, and should work, since the glaze script only uses the transmittance and reflectance values for it's models.
Creating a model that properly accounts for the deepening hue experienced at off-angle transmission through colored glazing would require hand-modeling, since the glaze script only considers a surface coating. I don't know the construction of the Evergreen glass, so I'm not sure what's appropriate.
Date: January 16, 2009 6:51:56 AM PST
Hi Galen,
Note for Viracon:
so
type = VE = Low-E
color = 2 = Green
Tr Tg Tb
Hope this helps.
