Hi everyone,
I'm doing a glare study with radiance and Ecotect.
Fristly i've created my 3d model in Ecotect, then i've exported it in radiance to calculte the lumiance in cd/m².
No problem for this part.
Secondly I'm using the function findglare and then glarendx, to compute a glare index.
When i'm writing my function findglare in my command window like this: findglare -p RCP_c3.pic > glaresult.glr
I've got en error message: "findglare: picture read error"
or if i'm using the method glare, i've got the same problem: "must have view or picture"
How can i fix it?
Thanks for your help,
Alexis Loubeyre.
glare index.
Are you aware of the shiny new 'evalglare'?
Is the picture a complete Radiance HDR image? Can you display
it in the Ecotect picture viewer? Have you modified the picture after
the rendering (reduced size, pcond)?
What do you get when you type the command
getinfo RCP_c3.pic
On Wed, Nov 17, 2010 at 10:55 AM, alexis Loubeyre <[email protected]> wrote:
Hi Alexis,
How did you set up your view for RCP_c3.pic? Findglare expects a fisheye (180h x 180v) view. If it does not get it then it reports an error/warning message.
Note also there is the new program evalglare for glare analysis:
http://www.ise.fraunhofer.de/areas-of-business-and-market-areas/applied-optics-and-functional-surfaces/lighting-technology/lighting-simulations/radiance/radiance?set_language=en&cl=en
# Jack de Valpine
On 11/17/2010 10:55 AM, alexis Loubeyre wrote:
Hi everyone,
How can i fix it?
Alexis Loubeyre.
You can now even do annual daylight glare probability calculations using Daysim 3.1 which contains a new subprogram written by Jan Wienold called gen_dgp_profile.
Christoph
From: [email protected] [mailto:[email protected]] On Behalf Of Jack de Valpine
Sent: Wednesday, November 17, 2010 11:22 AM
Subject: Re: [Radiance-general] Glare Calculation
Hi Alexis,
# Jack de Valpine
Hi everyone,
How can i fix it?
Alexis Loubeyre.
Hi Jack and Thomas,
Thank you for your help, I tried evalglare yesterday and he worked well.
But regarding my results have got couple of questions:
- i'm doing a glare study for an office (10m depth). I think glare will not be a problem for a person located at 9m away from the window, isn't it?
- when my calculation is completed, i've 2 warnings messages:
low brightness scene
vertical illumiance < 380 lux.
Do they impact the calcul?
So should i proceed a glare study only for the first 5m from the window?
How can i fix the warnings?
Alex
Date: Wed, 17 Nov 2010 11:22:18 -0500
To: [email protected]
Hi Alexis,
# Jack de Valpine
Hi everyone,
How can i fix it?
Alexis Loubeyre.
_______________________________________________ Radiance-general mailing list [email protected] http://www.radiance-online.org/mailman/listinfo/radiance-general
Hi!
Hm, that may be to easy... e.g. if your office is on the West facade and you directly look into the sun, it may be even worse at 9m distance...
Evalglare includes the vertical illuminance into its glare predictions, and (Jan can tell more about this) has been developed under conditions with higher vertical illuminance. So look at all the 9m, but be careful with those low-illuminance-locations.
No way to fix, it is a warning to catch your attention, not a bug to fix
Hi Jack and Thomas,
If you assume a standard workplace lighting level you could
introduce artificial lighting to raise the vertical illuminance to
500 lux. Evalglare might be happier with that (or it expects far
more than that; I honestly don't know).
Evalglare has been verified in a study on a small office space.
I'm sure Jan has put some thought into the general application
for this new metric. You can find his dissertation here:
http://www.ise.fraunhofer.de/veroeffentlichungen/nach-jahrgaengen/2010/buecher-und-beitraege-zu-buechern/dayligth-glare-in-offices
I would first verify that evalglare produces reliable results
in this office space. And then just go ahead and test the
full depth of the office. If you get a low probability for glare
that's also something to show.
Nothing to fix; just make sure your using the right tool here.
On Thu, Nov 18, 2010 at 4:49 AM, alexis Loubeyre <[email protected]> wrote:
Hi!
vertical illumiance< 380 lux.
One note on the terminology, as this causes confusion often. Evalglare intruduces illuminance on the eye plane (if you think of a human eye as a flat sensor) into the calculation, which stabilizes results for extended, non-uniform sources (window seen from close with a lot of detail behind). This is referred to as vertical illuminance (as illuminance on a vertical plane). And completely different from the typically workplane illuminance, which would be referred to as horizontal illuminance or illuminance that a infinitely small imaginary horizontal surface at e.g. 0.9m heigth would receive.
