hello folks.
i have files (fish eye rendered images) of my project. im doing glare
analysis using Evalglare program and following the tutorial by Shelby Doyle
and Christoph Reinhart in a step by step manner.
the mistake what i have done is: i have rendered all the images in
hemispherical view (vth) and the evalglare program takes only vta i.e
angular.
it took long to render those images around 150 files. this means i have to
render everyhting again by changing the the view type to angular and render.
my doubt is is there any other method where i can get the glare analysis
done with the hemispehrical view itself which is also 180degree fish eye.
this will save my time.
thanks alot.
will be really helpful if i get the solution
thanks
regards
dhaRam
Hi Dharam,
I guess you would be able to implement a reprojection for the images, either using Radiance's tools or any other software. You could e.g. start with vwrays -vta (...), which would give you for each pixel of your required -vta-projection the corresponding vectors. Using rcalc, you could calculate backwards at which pixel-coordinates in a vth-projected image of given dimensions the pixel-value for this direction is found. The problem is that there will be some interpolation needed in the process. I am not sure whether this will be faster then re-rendering the images. Did you keep all the files for the renderings, especially the ambient data? Depending on how you did the renderings, doing a second run with only changed view-parameters, but existing ambient cache data could be very quick.
I agree with Lars. I would rather re-render the images.
Too bad that I missed the Radiance workshop. I was in Germany celebrating my Grandpa's 95th birthday.
Christoph
Sent: Monday, August 29, 2011 10:18 AM
Subject: Re: [Radiance-general] glare analysis
Hi Dharam,
Actually, you should be able to reproject the pixels using pinterp. Try the following:
pinterp -vf rend_vth.hdr -x orig_xres -y orig_yres -vta rend_vth.hdr 1.0 > rend_vta.hdr
Date: August 29, 2011 6:36:47 AM PDT
hello folks.
i have files (fish eye rendered images) of my project. im doing glare analysis using Evalglare program and following the tutorial by Shelby Doyle and Christoph Reinhart in a step by step manner.
the mistake what i have done is: i have rendered all the images in hemispherical view (vth) and the evalglare program takes only vta i.e angular.
it took long to render those images around 150 files. this means i have to render everyhting again by changing the the view type to angular and render.
my doubt is is there any other method where i can get the glare analysis done with the hemispehrical view itself which is also 180degree fish eye. this will save my time.
thanks alot.
thanks
regards
dhaRam
Greg, I had NO clue that pinterp can be used as a tool for reprojection, even though I just found it is all written in the manpage. For me, it was always an animation tool to interpolate in between frames.
Great!!!
Lars.
Hi Lars,
It's a good day when I can teach _you_ something new about Radiance!
Date: August 29, 2011 9:02:04 AM PDT
Great!!!
Lars.
thank you very much sir. il surely try and post u the result...
thanks alot..
regards
dhaRam
Hi Greg! Great news for you: there is plenty of potential left then for having good days
Lars.
good evening sir.
actually im using "*.pic*" files .. i guess instead of .hdr i can replace it
with .pic .....am i rite sir? or will it make a difference
and i did this and an error message is displayed "read error"
can u guide me sir.
[i went through the userman and there is a command for changing angular to
hemispherical fish eye and i need the other way round.
'pinterp -vf fish.hdr -vth -ff fish.hdr 1 > hemi.hdr'
thank you sir
regards
dhaRam
Hi dhaRam!
In old times, we used .pic (picture) as a file extension in Radiance. This however caused some confusion, as there are a lot of differen formats using the same extension. So some years ago, folks started to name Radiance "image" data files .hdr (high dynamic range). This is also officially registred as a mime-type now, and in general is preferred. However Radiance does not really care about the name of your files.
So if your vht-projected image is in file fish.pic and you want to keep the old naming, just adopt the command line accordingly.
will thus become
pinterp -vf fish.pic -vth -ff fish.pic 1 > hemi.pic
BUT: If you have a closer look at Greg's mail, you will find that you do something quite different, and I do not really know why. Why do you use other parameters then Greg proposed?
hello sir.
that was exactly i was confused about. in Greg's mail he mentioned about x
res and y res ..... so i was confused with that and hence again mailed back.
the method given is angular to hemispherical ......and i need the other way
round.......so if i use the same command by just replacing fish (angular)
with hemispherical wil the commnad be same .... ( im supposing no) ... pls
let me kno about it sir...
thank you..
p.s- - as im exploring radiance more and more its getting interesting....
and i want to thank you for it sir....
thanks..
regards
dhaRam
Hi dhaRam,
Your initial e-mail said you had -vth images and needed -vta, so that's the way I wrote the pinterp command, giving the original view first, then updating it with '-vta'. The -x and -y resolution options are needed because pinterp otherwise defaults to 512x512, and you may not want that. The default filling option ('-fa') should work fine in your case, which is why I didn't specify anything for -f. Using '-ff' may result in some black pixels, which you don't want to send to evalglare as it would skew your results.
A little experimentation should resolve any outstanding issues.
Date: August 30, 2011 8:01:53 AM PDT
hello sir.
that was exactly i was confused about. in Greg's mail he mentioned about x res and y res ..... so i was confused with that and hence again mailed back.
the method given is angular to hemispherical ......and i need the other way round.......so if i use the same command by just replacing fish (angular) with hemispherical wil the commnad be same .... ( im supposing no) ... pls let me kno about it sir...
thank you..
p.s- - as im exploring radiance more and more its getting interesting.... and i want to thank you for it sir....
thanks..
regards
dhaRam
