Schorsch,
I've got a spelling correction for RRadout/README.md. Would you mind
granting me "contributor" permissions? Or would you rather I just e-mail it
to you?
Randolph M. Fritz, Lighting Design and Simulation
+1 206 659-8617 || [email protected]
On Thu, Mar 3, 2016 at 9:02 AM, Georg Mischler <[email protected]> wrote:
While at it, I created three seperate projects on GitHub:
1.
GitHub - gmischler/Torad: An Autolisp application for exporting geometry data to the Radiance lighting simulation package
Mostly for historical reasons, and to get the hang of the system.
2.
GitHub - gmischler/Dxf2rad-Radout: Export geometry from Autocad/Intellicad and translate from DXF files to Radiance scene description files.
Yes, the two share most of the codebase, and are now available with
a MIT license too. Version 1.1 can also create view files.
Binaries are available from my own site. If anyone wants to contribute
any other platforms, I'll be happy to publish them there as well.
In the case of dxf2rad, this would probably first be Darwin on various
types of hardware.
With Radout, someone with a more recent Autocad and some experience with
the SDK should be able to port it with little effort. I still need
to update the R15 download on my site to include the ACIS enabled version.
3.
GitHub - gmischler/RRadout: Python module for Autodesk Revit, exporting geometry data to Radiance
Last but not least.
As already mentioned for this one, contributions welcome and necessary!
Any further related discussions should probably go to radiance-dev.
Have fun!
-schorsch
Radiance-dev mailing list
For simple documentation typos, email is probably best, because those
most likely exist on the web site as well (after checking myself,
I just fixed several instances of "seperate", one of my favourites).
For code fixes, the standard Git method seems to be pull requests.
If you want to help extending and refactoring the program, I can
of course give you contributor status.
-schorsch
Am 2016-03-04 03:14, schrieb Randolph M. Fritz:
Schorsch,
e-mail it to you?
1.
GitHub - gmischler/Torad: An Autolisp application for exporting geometry data to the Radiance lighting simulation package [1]
2.
GitHub - gmischler/Dxf2rad-Radout: Export geometry from Autocad/Intellicad and translate from DXF files to Radiance scene description files. [2]
contribute
various
types of hardware.
with
version.
3.
GitHub - gmischler/RRadout: Python module for Autodesk Revit, exporting geometry data to Radiance [3]
Last but not least.
necessary!
Have fun!
-schorsch
com
+schorsch.com [4]+ -- lighting design tools --
http://www.schorsch.com/ [5]
http://www.radiance-online.org/mailman/listinfo/radiance-dev [6]
Links:
[1] GitHub - gmischler/Torad: An Autolisp application for exporting geometry data to the Radiance lighting simulation package
[2] GitHub - gmischler/Dxf2rad-Radout: Export geometry from Autocad/Intellicad and translate from DXF files to Radiance scene description files.
[3] GitHub - gmischler/RRadout: Python module for Autodesk Revit, exporting geometry data to Radiance
[4] http://schorsch.com
[5] http://www.schorsch.com/
[6] http://www.radiance-online.org/mailman/listinfo/radiance-dev
The errors in separate were exactly what I had in mind, so that's solved.
"For code fixes, the standard Git method seems to be pull requests." Well,
but eventually you have to push them. Or do you mean doing a "pull" on
GitHub itself?
I'd love to work on these things but, as usual, not enough time and, in
this case, no current Revit license; the thing is appallingly expensive.
-schorsch
Schorsch,
e-mail it to you?
1.
2.
contribute
various
types of hardware.
with
version.
3.
Last but not least.
necessary!
Have fun!
-schorsch
com
Links:
Well, but eventually you have to push them. Or do you mean doing a
"pull" on GitHub itself?
I'm still figuring this out myself. Here's my current understanding:
A "pull request" is a request to the maintainer to merge changes from a
branch or a fork into the trunk. Since anyone can easily fork a project,
this seems the easiest way to contribute smaller or occasional fixes.
Not to confuse with the normal "pull" and "push" commands.
in this case, no current Revit license; the thing is appallingly
expensive.
That seems to be a common problem. I'm hoping for people with access
at work or at school. It doesn't necessarily have to be a brand new
release though. I'm not sure when they introduced the "Custom Exporter"
API, but I think it was before Revit 2014.
-schorsch
Am 2016-03-04 22:09, schrieb Randolph M. Fritz:
That's exactly right. Pull requests leave a nice paper trail of who did
what, and who requested what, but only work within the sphere of Git.
Randolph, you could also just make a diff/patch of your changes on your
branch ('git diff > changes.patch') and send to Schorsch, which he can
apply manually ('git apply changes.patch'):
https://git-scm.com/docs/git-diff
https://git-scm.com/docs/git-apply
This method works across version control systems, and is what I do to get
my changes (managed on GitHub) to Greg (who's using CVS).
So what’s the sequence? First I clone the repo, so I have my own copy, make some changes on my own copy, test them, commit them locally, decide to submit them, and then what do I do to upload them to you for consideration?
Rob, Schorsch seems already to have picked up the problems and fixed them, so no need to send a patch.
Randolph
Git terminology may be confusing at times. This helped me quite a bit:
The typical situation is to create a "fork" first, which will give you
a copy of the project on GitHub. The fork will maintain its connection
to the original, so it can be merged back later.
In contrast, "cloning" means to pull something to your local system
for editing.
Once you have commited and pushed your changes to the fork, you can
then send a pull request to the original project.
Pull requests should really be called "merge requests".
Technically, the same effect could be had by creating a branch within
the original project. A fork has the advantage that the original author
doesn't get involved until changes have been made, hopefully tested,
and a pull request comes in about them. You can probably best think
of a fork as an "external branch".
Anything else we'll just have to experiment with, as soon as the
opportunity arrives.
-schorsch
Am 2016-03-05 02:42, schrieb Randolph Fritz:
consideration?
Pronoun troubles: who is doing what to which where?
So is this correct:
1. I first use the "fork" button to create my own copy of the repository
on GitHub
2. Then I use "git clone" on my own system, referencing my fork. This
downloads the repository to my system
3. Commit my changes on my system.
4. Use "push" on my system to upload my changes to my fork of the
project on GitHub
5. Then use GitHub's "New Pull Request" button on your repository to
submit a pull request to you, who will (if you like my changes) incorporate
my changes in your repository.
Git documents (and perhaps this is true of most free open source
documentation) seem to be written by people who know git for people who
know git. This makes the lives of people who don't know git difficult.
Correct on all points.
Actually, I'm not absolutely certain on which project you'll have to press
"New Pull Request", but that will be easy to find out.
I've probably been guilty of your #6 myself...
-schorsch
Am 2016-03-05 20:26, schrieb Randolph M. Fritz:
So is this correct:
* I first use the "fork" button to create my own copy of the
repository on GitHub
* Then I use "git clone" on my own system, referencing my fork. This
* Commit my changes on my system.
* Use "push" on my system to upload my changes to my fork of the
project on GitHub
* Then use GitHub's "New Pull Request" button on your repository to
incorporate my changes in your repository.
who know git. This makes the lives of people who don't know git
difficult.
I’m pretty sure it’s on yours, since you’re the one who receives the pull request.
I've probably been guilty of your #6 myself…
Randolph
1.
2.
types of hardware.
3.
Last but not least.
Have fun!
-schorsch
