Getting the focal length of a Radiance camera
Hopefully this is a simple question:
Is it possible to get the focal length of a camera view from within
Radiance?
I know that the view angle specification makes this unnecessary as an
input parameter but was wondering if it is possible to reconstruct the
physical camera properties from only a Radiance view description.
Cheers
Rich
(Hoping to have a decent animation and the Maya2Rad tools online
soon.promises, promises ;-))
____________________________
Richard Gillibrand
Department of Computer Science,
University of Bristol,
Tel: 0117 9545256
Hi Rich,
Marcus Jacobs asked a similar question about focal lengths last month on this group (Oct. 19th, in fact).
For a 35mm frame (which measures 36x24mm on the actual exposure), the equation for the horizontal and vertical view angles (in degrees) is:
  h = 2*180/PI*atan(36/2/f)
  v = 2*180/PI*atan(24/2/f)
To derive the focal length from the view angle, you just invert these:
  f = 36/2/tan(PI/180/2*h)
  f = 24/2/tan(PI/180/2*v)
As you can see, there are two formulas above, which means that you can derive the focal length from either the horizontal or the vertical view angles, but they won't necessarily agree. This is obvious because any given Radiance view may not have the correct image aspect ratio to match 35mm (or any other format) film. You have what is known in math as an "overdetermined problem." You can choose to ignore this and simply average the results from these two formulas, or pick the larger or smaller of the two, depending on whether you wanted to fill the frame completely or keep the image with black borders (i.e., "letterbox" format).
Date: Wed Nov 12, 2003 4:10:34 AM US/Pacific
Is it possible to get the focal length of a camera view from within Radiance?
I know that the view angle specification makes this unnecessary as an input parameter but was wondering if it is possible to reconstruct the physical camera properties from only a Radiance view description.
Cheers
Rich
Greg Ward wrote:
Hi Rich,
Actually, the focal length is determined by the largest
dimension of the picture, the diagonal, which makes it
somewhat independent of the aspect ratio.
The normally used formula for 35mm film pictures
therefore goes like this:
  f = 43.27/2/tan(PI/180/2*h)
-schorsch
Ah!
Thanks Greg, I thought the question was familiar when I asked it!
Rich
Richard Gillibrand
Tel: 0117 9545256
Sent: 12 November 2003 16:45
Cc: R Gillibrand
Subject: Re: Getting the focal length of a Radiance camera
Hi Rich,
Radiance?
Cheers
Rich
R Gillibrand wrote:
Ah!
Rich
btw: there's a search engine combing though the mailman archives every night: http://www.radiance-online.org/search.html
Peter Apian-Bennewitz wrote:
R Gillibrand wrote:
Ah!
Rich
... and The Mighty Google also crawls the site. You can restrict a Google search to a specific domain by adding "site:domain.com" in your search string:
Richard, you could locate the juicy bits of your recent request by entering the following srting at Google:
focal length site:www.radiance-online.org
Have fun, and thanks again to Peter for hosting this site & list. It's a great resource!
      Rob Guglielmetti
e. rpg@rumblestrip.org
w. www.rumblestrip.org
