Genskyvec.pl error on Windows (was: Re: Python script)
Hi Rob,
I can't test it for you, but I suspect the line:
  } elsif (/\sskyfunc\s*$/) {
is the problem. Try removing the final '\s*' to make it:
  } elsif (/\sskyfunc$/) {
and see if that works. It works on Unix, so if it solves the problem, I should check it in. I don't know why it would be an issue, but I can't see what else could be failing.
From: "Guglielmetti, Robert" <Robert.Guglielmetti@nrel.gov>
Date: July 18, 2012 12:43:27 PM PDT
Looked at this a bit this morning, and actually I can't get the correct behavior from Genskyvec on Windows even using the program directly. A really simple example:
C:\gensky 6 21 12 <return>
# gensky 6 21 12
# Local solar time: 11.84
# Solar altitude and azimuth: 75.5 -8.8
# Ground ambient level: 18.2
void light solar
3 7.18e+006 7.18e+006 7.18e+006
solar source sun
4 0.038263 -0.247650 0.968094 0.5
void brightfunc skyfunc
2 skybr skybright.cal
7 1 3.16e+001 3.02e+001 1.65e+000 0.038263 -0.247650 0.968094
C:\gensky 6 21 12 | genskyvec.pl -m 1
Bad sky description!
Gensky prints a valid description to STDOUT, but when I pipe it to genskyvec, it fails the error check loop in lines 25-45. I'm using v 2.8 of genskyvec.pl, from 2012.06.28. Ideas?
