genskyvec binary
Is anyone looking at converting genskyvec from a perl script to compiled code at all?
[IES]<http://www.iesve.com/>
Palbinder Sandher
Software Platform Engineer
T:
+44 (0) 141 945 8500
F:
+44 (0) 141 945 8501
http://www.iesve.com<http://www.iesve.com/>
**Design, Simulate + Innovate with the <Virtual Environment>**
Integrated Environmental Solutions Limited. Registered in Scotland No. SC151456
Registered Office - Helix Building, West Of Scotland Science Park, Glasgow G20 0SP
Email Disclaimer<http://www.iesve.com/disclaimer.html>
No one that I know of. What is the issue? It's pretty fast, so I assume you're looking to eliminate a dependency.
Rob Guglielmetti
NREL Commercial Buildings Research Group
Golden, CO 80401
From: Pally Sandher [[email protected]<mailto:[email protected]>]
Sent: Friday, March 07, 2014 01:31 PM Mountain Standard Time
Subject: [Radiance-dev] genskyvec binary
[cid:[email protected]]<http://www.iesve.com/>
Palbinder Sandher
T:
F:
It requires a Perl environment to run which isn’t as user friendly as a regular binary.
I’ve packed it into an executable using PAR::Packer but in my benchmark tests it’s about 20-30% slower than running the perl script since it has to decompress itself to a temporary location before it runs then clean itself up afterwards. When you’re running hourly sims for a full year (around 6000 sims discounting the hours without daylight) that 20-30% mounts up significantly (my benchmark went from 45 minutes down to 28 when switching to running the perl script instead of the packed binary).
This is on Windows using Strawberry Perl for all my Perl environment needs BTW.
Palbinder Sandher
T:
F:
Sent: 07 March 2014 20:55
To: 'code development'
Subject: Re: [Radiance-dev] genskyvec binary
Rob Guglielmetti
Golden, CO 80401
Palbinder Sandher
T:
F:
If you are using the Perez Sky Model, I would suggest you to use GENDAYMTX
somehow. Maybe write a 1-hour "wea" file, and run that program. Makes sense?
Bye
2014-03-17 7:42 GMT-03:00 Pally Sandher <[email protected]>:
It requires a Perl environment to run which isn't as user friendly as a
regular binary.
I've packed it into an executable using PAR::Packer but in my benchmark
tests it's about 20-30% slower than running the perl script since it has to
up afterwards. When you're running hourly sims for a full year (around 6000
BTW.
[image: IES] <http://www.iesve.com/&gt;
*Palbinder Sandher*
*Software Platform Engineer*
T:
F:
**Design, Simulate + Innovate with the *<Virtual Environment>***
SC151456
G20 0SP
Email Disclaimer <http://www.iesve.com/disclaimer.html&gt;
*From:* Guglielmetti, Robert [mailto:[email protected]]
*Sent:* 07 March 2014 20:55
*To:* 'code development'
*Subject:* Re: [Radiance-dev] genskyvec binary
Rob Guglielmetti
Golden, CO 80401
*Sent: *Friday, March 07, 2014 01:31 PM Mountain Standard Time
*To: *[email protected]
*Subject: *[Radiance-dev] genskyvec binary
code at all?
*Palbinder Sandher*
T:
F:
SC151456
G20 0SP
Radiance-dev mailing list
*Germán Molina L.*
Ingeniero Trainee
Hunter Douglas Chile S.A.
Celular +569 89224445
gracias.
OK yeah that's what I assumed. Good point about the load time, given the typical use case for gendaymtx (i.e. hourly calls). German's tip may be useful, since you can use epw2wea (a C program) to generate the hourly .wea files you'd need for that, but that's still a lot of annoying i/o. We do have some methods for dealing with OpenStudio's (many) dependencies — including perl — internally to OpenStudio, which may be of interest, Pally.
From: Pally Sandher <[email protected]<mailto:[email protected]>>
Reply-To: code development <[email protected]<mailto:[email protected]>>
Date: Monday, March 17, 2014 at 4:42 AM
Palbinder Sandher
T:
F:
Rob Guglielmetti
Golden, CO 80401
To: [email protected]<mailto:[email protected]>
Palbinder Sandher
T:
F:
