Hi Everybody,
I have an aim to find out the luminance of the sun after it hits a perfect diffuser. I'm sure i have done this the very long way round, but at least this step by step way i understand what is going on.
I have used gensky to create a sun, and have created a sky and a ground (see bottom).
Aside question- the default for meridian using gensky is -120, and as im in london i have put my meridian to 0. this seems to give me a negative azimuth angle for my early morning sun and a positive for my afternoon sun. this means that the sun is rising in the west and setting in the east…im sure its the other way round??? the first four lines of the 10am automatically generated gensky file can be seen below
# gensky 07 24 10 -a 52 -o 2 -m 0 +s
# Local solar time: 9.76
# Solar altitude and azimuth: 48.8 -52.0
# Ground ambient level: 18.3
I have created different files for the sun throughout one day, started and finishing at 7, so that i have 13 different sun's.
I have then oconv each file to my material file, found a nice view directly at the sun for each time in rview and then rendering the image in rpict and finally pcond each image with a -h- option to get a good exposure level. So i have 13 images all looking directly at the sun. When i then click on a point and press l it gives me a value for (i think???) luminance.
I now want to place a perfect diffuser with a normal pointed directly at the sun in each of these 13 positions and measure the illuminance reflecting off of the diffuser. My big question is, how do i orientate the diffuser so that it is normal to the sun each time, and any recommendations as to what material/values i should make the diffuser from??
My sky.mat file just for completion
skyfunc glow sky_glow
4 1 1 1 0
sky_glow source sky
4 0 0 1 180
skyfunc glow ground_glow
4 1 1 1 0
ground_glow source ground
4 0 0 -1 180
# ground plane
void plastic ground_mat
5 .28 .18 .12 0 0
ground_mat ring groundplane
8 0 0 -.01
0 0 1
0 30
Thanks
Chris
This e-mail and any attachments may contain confidential and/or
privileged material; it is for the intended addressee(s) only.
If you are not a named addressee, you must not use, retain or
disclose such information.
NPL Management Ltd cannot guarantee that the e-mail or any
attachments are free from viruses.
NPL Management Ltd. Registered in England and Wales. No: 2937881
Registered Office: Serco House, 16 Bartley Wood Business Park,
Hook, Hampshire, United Kingdom RG27 9UY
