If -g is given as the last argument to the gensky command, a bus error or segmentation fault results. That is:
gensky 3 31 10:00 -g -c
works, but
gensky 3 31 10:00 -c -g
fails.
Randolph M. Fritz • [email protected]
That's because -g is expecting an argument (the ground reflectance). If you give "-c" after, it probably calls atof("-c") which returns 0.
In general, Radiance doesn't have very paranoid argument checking. If you don't give a legal command line, many Radiance programs just muddle through (or crash if they try reading past the last argument). The exceptions to this are the rendering programs and a few utilities that call badarg() to check command argument types.
Date: February 7, 2011 1:29:09 PM PST
works, but
fails.
So is the default never used? Or only when -g is not given?
works, but
fails.
Huh? You get the default value if you *don't* specify a -g option. If you use -g 0.30, you would get a ground reflectance of 30% instead of the default 20%.
Make sense?
Date: February 9, 2011 10:05:17 AM PST
works, but
fails.
Radiance-dev mailing list
The default rfl value for -g is used when -g is not given. That's the
definition of default, isn't it? =8-)
Greg is saying that -g needs an argument, for the ground refl. It's not an
on/off switch.
1617 Cole Blvd MS:RSF202
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
E. [email protected]
works, but
fails.
Randolph M. Fritz € [email protected]
Environmental Energy Technologies Division € Lawrence Berkeley Labs
BTW, the default value for -g is not printed in the manpage, but it's 20%
(you can find it in gensky.c, and Axel Jacobs mentions this in his
rtcontrib tutorial, I believe).
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
on/off switch.
Golden, CO 80401
T. 303.275.4319
F. 303.630.2055
works, but
fails.
There is a "gensky -defaults" report if you like:
+s # Sunny sky with sun
-g 0.200000 # Ground plane reflectance
-t 2.450000 # Atmospheric turbidity
-a 37.815214 # Site latitude (degrees)
-o 122.040010 # Site longitude (degrees)
-m 120.000281 # Standard meridian (degrees)
Date: February 9, 2011 10:29:00 AM PST
Ooof! Something really weird happens when I run:
gensky 6 21 10:30 -g -c
Not sure what it does, but it includes a sun.
Time to rerun some simulations...
Randolph
Make sense?
works, but
fails.
It generates an intermediate sky with a sun...
Randolph
Randolph
the default 20%.
Make sense?
works, but
fails.
