I wish to render a scene and output a black and white image where the black areas have 0 irradiance and everything else is white.
I then want to pcomb this over another image so that on that image all the black parts of the mask appear in black, but wherever the mask is white, the underlying picture shows through.
How can I do this? I can see it should be possible, but the devil is in the details it seems...
Chris
This command should do what you expect:
pcomb -e 'ro=li(1)*ri(2);go=li(1)*gi(2);bo=li(1)*bi(2)' mask.pic picture.pic >result.pic
At 28.01.2005 15:06, you wrote:
Chris
Ah yes, and I can threshold my mask image like this:
pcomb -e 'lo=if(li(1), 1, 0)' input.pic > mask.pic
Chris
Be careful with thresholding, since the if() function takes any non-zero positive value as "true". For this reason, it's generally a good idea to use some small epsilon to avoid errors, like:
if(li(1)-1e-7, 1, 0);
-G
From: Christopher Kings-Lynne <chriskl@familyhealth.com.au>
Date: January 28, 2005 6:58:53 AM PST
Chris
In my case, the areas are in total shadow (ab=0), and hence have an input brightness of exactly zero.
So in your example above, you're also including areas that have a very slight amount of brightness, right?
Chris
A radiance value of 10^-7 is negligible. However, even if your value _should_ be exactly zero, round-off error could bring it up to as high as 10^-15 or so, which would cause your if statement to return 1. I'm just suggesting that you be careful when comparing floating point values.
-G
Date: January 28, 2005 7:17:41 AM PST
Chris
