Hello All,
If I want to show cumulative results (images), eg lux hrs per year or lux hrs per month, what is the right way to do this for the 3 phase with dctimestep. So for example with an annual sky matrix generated with gendaymtx, do I sum this up somehow and then apply?
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
channeling technology for superior design and construction
I think the simple answer is that gendaymtx currently doesn't support 3 phase. Weah.
Sent: Friday, June 07, 2013 11:24 AM
Subject: [Radiance-general] gendyamtx - cumulative results
Hello All,
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
Sorry, but why not? I think Andy demos (for photocells) in the last version of his tutorial...
Hello All,
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
Guess I'd better read that thing. Initially, it did not support 3 phase. Hopefully Andy or Greg or someone else who actually knows what the hell's going on can answer your question. =8-)
Hello All,
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
Hi Jack,
I think the easiest method would be to extract the hours you want to accumulate from your WEA file, send them through gendaymtx and dctimestep like so:
gendaymtx -of subyear.wea > subyear1.smx
dctimestep -if -n 720 -o win1w_%03d.hdr winterior1w.vmx blinds30.xml westelev.dmx subyear1.smx
pcomb win1w_*.hdr > win1w_sum.hdr
rm win1w_*.hdr
This will generate 720 images corresponding to a month's worth of hourly inputs from window #1 on the west elevation. The above steps (except the first) will have to be repeated for your different windows. If you do a year at a time, you'll have to sum all these images together in batches, since pcomb only handles up to 1024 images at a time (so long as you don't run into system limits first).
I hope this addresses your question. To be honest, I've never done anything like this and I'm not entirely sure I got it right.
Date: June 7, 2013 11:26:03 AM PDT
Hello All,
Actually, I just realized that you could shortcut this quite a bit by summing together your time steps out of gendaymtx. You should be able to run:
gendaymtx -od jan.wea | total -id3 -720 > jan.sky
dctimestep winterior1w.vmx blinds30.xml westelev.dmx jan.sky > win1w_jan.hdr
Again, you'll need to run dctimestep for each of your windows and sum the results, but it should be a whole lot quicker this way. If you want to sum up a whole year, just change the -720 option on total to -8160 (or whatever).
Date: June 7, 2013 11:44:02 AM PDT
Hi Jack,
rm win1w_*.hdr
Hello All,
Excellent! This is what I was wondering about as a solution.
I will give this a try.
Jack
Sent from my Verizon Wireless 4G LTE DROID
Hi Jack,
rm win1w_*.hdr
Hello All,
Oh, yeah, and the number used in total needs to match the number of days in the month, so I kind of blew it assuming January has 30 days in my example! (Should have been "total -id3 -744".) This works because gendaymtx outputs time steps as columns in the matrix (inside sort). The final output will contain 3 ASCII triplets for each patch, so you don't need to change anything for different -m options to gendaymtx. You just need to make sure your matrix dimensions are expecting the right number of patches.
Sent from my iPad
On Jun 7, 2013, at 2:20 PM, Jack de Valpine <[email protected]> wrote:
Jack
> From: Greg Ward <[email protected]>
> Hi Jack,
> rm win1w_*.hdr
> Cheers,
> -Greg
>> From: Rob Guglielmetti <[email protected]>
>> - Rob
>>> -Jack
>>>> - Rob
>>>> From: Jack de Valpine [mailto:[email protected]]
>>>> Hello All,
>>>> Thanks,
>>>> -Jack
