Gendaymtx, proper energy balance
Dear all
I’m running a series of 3PM daylight studies and 2PM façade radiation studies, in the same fashion as presented in: https://www.radiance-online.org/learning/tutorials/matrix-based-methods
Hence for illuminance based simulations I run:
gendaymtx -O0 xxx.wea > xxx.smx
… (rfluxmtx, rfluxmtx, dctimestep)
rmtxop -fa -c 47.4 119.9 11.6 xxx.rgb > xxx.ill
And for the irradiance based simulations I run:
gendaymtx -O1 xxx.wea > xxx.smx
… (rfluxmtx, dctimestep)
rmtxop -fa -c 0.265 0.670 0.065 xxx.rgb > xxx.wm2
Since I’m only interested in illuminance and irradiance, color information can be neglected. Post processing in only one channel enables me to speed up the dctimestep- rmtxop-daylightmetrics computations, due to the smaller matrix/vector sizes e.g. making a CUDA based implementation.
The default settings of the gendaymtx sky color is: “-c 0.960 1.004 1.118”. There is an example with “–c 1 1 1” yielding an uncolored sky, but what is the constraints on the “-c” settings in gendaymtx when it should yield a proper energy balance? And subsequently how is “-c 0.960 1.004 1.118” derived?
Any help understanding this is highly appreciated.
Best regards Tobias
The numbers in -c 47.4 119.9 11.6 and -c 0.265 0.670 0.065 relate to the weighting applied to the R, G and B (respectively) channels to account for the V-Lambda function (Wikipedia link, which I think does an okay job here).
I believe the sky color -c 0.960 1.004 1.118 relates to a blue sky as the blue channel is slightly higher than green and red. Multiplying those numbers with the individual weighting factors for the V-Lambda function will yield 1 or 179.
0.265*0.960+1.004*0.67+1.118*0.065=0.99975
47.4*0.96+119.9*1.004+11.6*1.118=178.852
For illuminance calculations as long as you still get a value of 1 or 179 with the above coefficients, I think you’d be fine with regards to energy balance. I guess in the case of irradiance calculations, the photopic efficiency part isn’t really relevant, so your coefficients of -c 1 1 1 should be fine.
Sarith
PS: The number 179 relates to the luminous efficacy of equal energy white light when integrated from 380nm to 780nm. Luminous efficacy is defined as per 683lumens/W at 555nm (green). I tried to do the math and derive that 179 for myself using spectral data for V-Lambda at 5nm intervals. I got around 180.21, which I guess is close enough (see cell 88C in Dropbox).
