gendaylit, dls, glare factors
i m osx beginner.
also rad beginner.
everything beginner.
you ll realize soon, reading my three questions ..;-)))))))))))
FIRST QUESTION:
while trying to compile gendaylit (on osx UNIX) i get this error:
% make
cc -Ae -g -c sun.c
cpp-precomp: Invalid option '-Ae'
make: *** [sun.o] Error 1
so i removed the -Ae tag (HP UNIX?) but with -ansi tag ...
... and another error message appeared
%make
cc -ansi -c sun.c
cc -ansi -c fropen.c
paths.h:62: only 1 arg to macro 'fropen' (2 expected)
fropen.c:20: only 1 arg to macro 'fropen' (2 expected)
fropen.c:20: illegal external declaration, missing `;' after `fropen'
fropen.c:26: illegal external declaration, found `if'
fropen.c:43: illegal method selector, found `1'
fropen.c:44: illegal method definition, missing `{' after `/'
fropen.c:46: illegal external declaration, found `if'
cpp-precomp: warning: errors during smart preprocessing, retrying in basic mode
make: *** [fropen.o] Error 1
so i lost my faith...
...thinking i had to edit the c source.
is anybody so kind and nice to help me compiling such program?
SECOND QUESTION:
i found a java program, DLS, and i tried to use it.
BUT although i have a working radiance install on my ibook this program tells kindly that radiance cannot run on a MAC.
i think it understands that ti's working on apple VJM and stops.
any idea about the way of telling it it's wrong, that radiance CAN run on macOSX?
THIRD QUESTION:
glare calculation.
if i use IES files to generate proper radiance light sources, does radiance consider them in glare calculation?
which trick should i use to solve this (mapping luminance distribution on a glow material?)?
THANKS A LOT
pillo.pillo@tin.it
pillo wrote:
i m osx beginner.
also rad beginner.
FIRST QUESTION:
% make
cc -Ae -g -c sun.c
yeap -Ae is for HPUX. One has to handtweak the compile options.
%make
cc -ansi -c sun.c
basic mode
Apparently OS-X on Mac has some macro fropen defined. The function
prototype in paths.h specifies only one argument for the function defined
in fropen.c .
Try to add a #undef fropen in line 9 of paths.h .
-Peter
thanks a lot for giving me the LIGHT!!!!
now IT WORKS!!!
WWWWWW
pillo.pillo@tin.it
PS other questions still remain unsolved... so if anybody knows about....
reply (1.74 KB)
Da: Peter Apian-Bennewitz <apian@pab-opto.de>
Data: 18/03/2002 10:51
A: radiance-general@radiance-online.org
Oggetto: Re: [Radiance-general] gendaylit, dls, glare factors
pillo wrote:
> i m osx beginner.
> also rad beginner.
> FIRST QUESTION:
> % make
> cc -Ae -g -c sun.c
> %make
> cc -ansi -c sun.c
> basic mode
in fropen.c .
-Peter
