I am trying to define a clear and overcast sky for a particular
location using gendaylit. I have collected global horizontal exterior
illuminance data, but no diffuse illum. or irradiance data, so I would
thus like to use TMY3 data. I am using DIVA-for-Rhino which requires
an input in W/m2 for gendaylit, so I have two options:
a) use the direct and diffuse horizontal irradiance values from the TMY3 file
b) divide the direct and diffuse horizontal illuminances by 179 lm/W
to obtain the irradiances
Which of these is the correct input for gendaylit?
What is the significance of the luminous efficacy used in Radiance
(179 lm/W)? The book "Rendering with Radiance" states that luminous
efficacy can vary from 50 to 150 lm/W depending on the type of sky or
light considered (p357). And indeed when I divide for example, diffuse
horizontal illum. data by 179, the irradiances I get are quite
different from those in the TMY3 file.
Does this mean that I should use the irradiance data from the TMY3 file?
Krystyna Zelenay
from the site (but not irradiance data).The default DIVA input is in terms of
direct horizontal irradiance (W/m^2) and
diffuse horizontalirradiance (W/m^2)
Is there a way to change the default input to
NORMAL horizontal ILLUMINANCE (lm/m^2) and
diffuse horizontal ILLUMINANCE (lm/m^2)
(i.e. similar to the -L option in the gendaylit command)
Alternatively, does anyone know how to go about converting illuminance
to irradiance data?
Thank you,
Krystyna
Hi Krystyna,
I suggest having a look at at Axel Jacobs document on "Understanding rtcontrib":
http://luminance.londonmet.ac.uk/learnix/docs/rtcontrib_lesson.pdf
On pages 30-32 he provide some excellent explanation of processing weather data for Radiance and gendaylit. According to this, the best data points to use are direct normal and diffuse horizontal irradiance (W/m^2) which should be provided to gendaylit AS IS (eg without any additional factoring for Radiance). Irradiance data points are suggested as the best option as apparently not all weather stations actually measure photometric data, meaning that such values if not measured are derived from the radiometric data points.
Note reading further will provide some potential cautions on gendaylit as well....
# Jack de Valpine
On 3/16/2011 3:11 AM, Krystyna Zelenay wrote:
Krystyna Zelenay
to irradiance data?
Thank you,
Krystyna
Dear Krystyna,
The DIAV-for-Rhino input for gendaylit is not ideal right now but we are
working on it. If you have measured global solar radiation that you want
to use to generate a Perez sky using gendaylit, you can - for example -
use a little program called 'gen_reindl' that comes with Daysim. Just
open a DOS command and type 'gen_reindl' and you will get a description
of the required input and resulting output file formats. The output
direct and diffuse irradiance are what you have to enter into the DIVA
dialogue box. As the name suggests, the program uses the 'Reindl model'
to generate direct and diffuse irradiances for global irradiances
(http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6V50-497TD1G-
1GR&_user=10&_coverDate=12%2F31%2F1990&_alid=1682991794&_rdoc=3&_fmt=hig
h&_orig=search&_origin=search&_zone=rslt_list_item&_cdi=5772&_sort=r&_st
=13&_docanchor=&view=c&_ct=5&_acct=C000050221&_version=1&_urlVersion=0&_
userid=10&md5=40baa0c089e7bf9f8f3a02f4581aafbe&searchtype=a) . The model
is not necessarily the 'best' model available any more. But, when I
wrote the program about eight years ago and it did a convincing job for
a site in Ottawa.
I hope that this helps.
All the best,
Christoph
Sent: Wednesday, March 16, 2011 3:12 AM
Subject: [Radiance-general] Gendaylit command
file
Krystyna Zelenay
terms of
to irradiance data?
Thank you,
Krystyna
Thank you very much for your input.
I am considering using horizontal (direct and diffuse) irradiance data
since this is the required DIVA input. However, now I am wondering if
I can actually use TMY3 data since I think these may be hourly
averages calculated for the 60-minute period preceding the timestamp.
While I could subtract 30 minutes from the timestamp, this would only
be an approximation at best.
I wonder if anyone knows of any sources of instantaneous GH direct and
GH diffuse irradiance data (required input for DIVA) or a way I could
use the TMY3 hourly averages?
Krystyna
On Thu, Mar 17, 2011 at 11:01 AM, Reinhart, Christoph <[email protected]> wrote:
Dear Krystyna,
a site in Ottawa.
All the best,
Christoph
file
Krystyna Zelenay
terms of
to irradiance data?
Thank you,
Krystyna
Hello everyone,
i am trying to use command gendaylit by i receive the following message:
# gendaylit 3 2 15 -a 42 -o 108 -W 100 100
file coeff_perez.dat cannot be opened
lect_coeff_perez does not work
file: "coeff_perez.dat" is not in the computer. Can you please give me
any solution??
Thank you very much
Sotiris
2011/3/18 Krystyna Zelenay <[email protected]>:
Krystyna
On Thu, Mar 17, 2011 at 11:01 AM, Reinhart, Christoph > <[email protected]> wrote:
Dear Krystyna,
a site in Ottawa.
All the best,
Christoph
file
Krystyna Zelenay
terms of
to irradiance data?
Thank you,
Krystyna
