I am back with more questions about genBSDF. I have modeled a window with
venetian blinds on the lower part and translucent louvers on the upper part
of the window. I tried to run genBSDF with my geometry including the
blinds, louvers, glazing and the window reveal, but I did not get any
results back after 14 hours.
I know genBSDF runtime is long, but I wonder if I am doing something wrong,
or if I could change anything in my model that could make genBSDF run
faster.
Attached are the geometry files. Here is what I typed:
genBSDF -n 12 +f +b -geom meter -t4 5 reveal_glazing.rad venetian80.rad
LChazed.rad > bsdf/v80_hazed_t45.xm
Leyla
reveal_glazing.rad (2.93 KB)
venetian80.rad (129 Bytes)
LChazed.rad (138 Bytes)
Hi Leyla,
All you can really do is play with the -c option and the rendering parameters. You probably don't want to change -c in this case, but you can make the rendering go faster by altering the default options, which are:
"-w -ab 5 -ad 700 -lw 3e-6"
You can try running:
genBSDF -n 12 +f +b -geom meter -t4 5 -r "-ab 3 -ad 500 -lw 1e-5" \
reveal_glazing.rad venetian80.rad LChazed.rad > bsdf/v80_hazed_t45.xml
Also, I noticed that your blind slat material has 10% specularity, which probably isn't realistic unless it has a metallic coating. I would expect the specularity to be 0.05 or less. You are also better off specifying a non-zero roughness value unless the slats are really mirror-smooth.
Date: September 17, 2013 4:02:53 PM PDT
I am back with more questions about genBSDF. I have modeled a window with venetian blinds on the lower part and translucent louvers on the upper part of the window. I tried to run genBSDF with my geometry including the blinds, louvers, glazing and the window reveal, but I did not get any results back after 14 hours.
I know genBSDF runtime is long, but I wonder if I am doing something wrong, or if I could change anything in my model that could make genBSDF run faster.
genBSDF -n 12 +f +b -geom meter -t4 5 reveal_glazing.rad venetian80.rad LChazed.rad > bsdf/v80_hazed_t45.xm
Leyla
Thank you Greg. I'll try that.
Leyla
On Tue, Sep 17, 2013 at 8:00 PM, Greg Ward <[email protected]> wrote:
Hi Leyla,
*Date: *September 17, 2013 4:02:53 PM PDT
run faster.
Leyla
