Hello all,
I recently started to experiment with Radiance and now I am experimenting on
the three phase method. I started with something very very simple to see how
it works and maybe compare the results with other simulation methods, before I
try to do something complicated.
I created a simple rectangular room that is lighted through another
rectangular box on top of the roof. This box I want to use to make a BSDF. It
is just a rectangular kind of pipe, with two of its surface (the one on top
and bottom) translucent, from which the light will enter the room.
I created the Daylight matrix for the upper part of this shape. Then I created
the rad files for the box's geometry and materials that are really simple.
However when I try to generate the BSDF, the genBSDF stops working. I tried to
use a different genBSDF (I found one of different size from WINDOWS software).
This one runs but at the end I get the message "Generation of Tensor Tree
BSDFs is not supported on windows". Anyone has any idea why I get these
errors? I am really new in this and maybe I miss something really obvious.
Thank you in advance,
Ariane
Hi Ariane,
You shouldn't be using the "-t3" or "-t4" option of genBSDF for the three-phase method. Without these options, you should not get the unsupported error.
Subject: [Radiance-general] genBSDF problem
Date: July 27, 2014 10:58:10 AM PDT
Hello all,
Ariane
This seems to work. Thank you very much!
Ariane
Hi Ariane,
Hello all,
the room.
Ariane
