genBSDF and rcontrib errror on Windows 10
Hi Radiance Online,
I have been getting a recurring error while trying to run genBSDF through the git bash console on a Windows 10 system. I have searched through quite a few forums, and of these Radiance-Online repository’s, however no-one seems to have had quite the same error. I get the following error:
[email protected] MINGW64 ~
$ genBSDF.pl C:/ladybug/Hyderabad/100mm_shading_screen/MSH2RADFiles/blinds.rad > C:/ladybug/Hyderabad/100mm_shading_screen/MSH2RADFiles/blinds_2.xml
rcontrib: system - cannot find function file "klems_full.cal": Invalid argument
C:/ladybug/BSDF/genBSDF.WPQU9v/behind.dat: cannot load matrix
C:\Radiance\bin\rmtxop.exe: operation failed on 'C:/ladybug/BSDF/genBSDF.WPQU9v/behind.dat'
Failure running rmtxop at /c/Radiance/bin/genBSDF.pl line 463.
I have changed the temp directory away from the traditional path variable in-case I didn’t have the right run-permissions for that folder. On our system, the C:/ladybug has read, write and execute permissions. Clearly this didn’t address the problem. My PATH and RAYPATH environment variables are as echoed:
$ echo $PATH
/c/Users/jamessheldon/bin:/mingw64/bin:/usr/local/bin:/usr/bin:/bin:/mingw64/bin:/usr/bin:/c/Users/jamessheldon/bin:/c/Radiance/bin:/c/Program Files (x86)/Panda Security/WaAgent/Common:/c/Users/jamessheldon/AppData/Local/Programs/Python/Python35-32/Scripts:/c/Users/jamessheldon/AppData/Local/Programs/Python/Python35-32:/c/Radiance/bin:/c/DAYSIM/bin:/c/Accelerad/bin:/c/Strawberry/c/bin:/c/Strawberry/perl/bin:.:/usr/bin/vendor_perl:/usr/bin/core_perl
$ echo $RAYPATH
.;C:\Accelerad\lib; C:\Radiance\lib;
I also receive the same error when trying to run the accelerad version of genBSDF. I am struggling to find a way of progressing with this error, as we get no further feedback from an error console or event viewer. Thanks in advance for any assistance :blush:
Warm Regards,
James Sheldon
MEng MA Hons. (Cantab.)
Environmental Designer
Atelier Ten
19A Perseverance Works, 38 Kingsland Road, London E2 8DD
T +44 (0)20 7749 5950
atelierten.com<http://www.atelierten.com/> | Twitter<https://twitter.com/atelierten?lang=en-gb> | LinkedIn<https://www.linkedin.com/company/atelier-ten>
[cid:[email protected]]<http://www.amazon.co.uk/Invisible-Architecture-Patrick-Bellew-al/dp/1780676867>
Building Services Engineers + Environmental Design Consultants + Fire Engineers + Lighting Designers
LONDON | GLASGOW | EDINBURGH | NEW YORK | NEW HAVEN | SAN FRANCISCO | DOHA | BANGKOK | SINGAPORE | MELBOURNE | SYDNEY
Atelier Ten is an accredited ISO 9001 and 14001 company and is a founding member of the UKGBC. This e-mail (and any attachments) may contain privileged and/or confidential information. If you are not the intended recipient of this e-mail you must not disclose, copy, distribute, disseminate or take any action in reliance on it. If you have received this message in error please notify the sender and then delete it from your system. Each year with Clear, we offset our expected CO2 emissions. Company Registration Number: 255 2224. Company Registered Address: 19A Perseverance Works, 38 Kingsland Road, London, E2 8DD
