http://www.cs.columbia.edu/CAVE/curet/
Columbia-Utrecht Reflectance and Texture Database
Kristin J. Dana
Bram Van Ginneken
Shree K. Nayar
Jan J. Koenderink
Researchers at Columbia University and Utrecht University have collaborated
in an extensive investigation of the visual appearance of real-world
surfaces. This joint effort, sponsored in part by REALISE of the European
Commission, the National Science Foundation and by DARPA/ONR under the MURI
Grant No. N00014-95-1-0601 has resulted in 3 databases:
BRDF (bidirectional reflectance distribution function) database with
reflectance measurements for over 60 different samples, each observed with
over 200 different combinations of viewing and illumination directions.
BRDF parameter database with fitting parameters from two recent BRDF models:
the Oren-Nayar model and the Koenderink et al. representation. These BRDF
parameters can be directly used for both image analysis and image synthesis.
BTF (bidirectional texture function) database with image textures from over
60 different samples, each observed with over 200 different combinations of
viewing and illumination directions. Each of these databases is made publicly
available for research purposes. For details about the measurements, and
fitting procedures a technical report and summary paper are provided. Also
see the following journal paper:
Reflectance and Texture of Real World Surfaces, K.J. Dana, B. van Ginneken,
S.K. Nayar and J. J. Koenderink,
ACM Transactions on Graphics, Volume 18, No. 1, pp. 1-34, January 1999
