Hi Alireza,
Did you generate the XML files yourself? The ones I downloaded via the
current version of the 5-phase bash script don't report this warning, which
I would say indicates a problem. You can download the XML files using:
curl -o bsdf/fullwindow_t45.xml
http://www.radiance-online.org/learning/tutorials/fivephasetutorialfiles/fullwindow_t45.xml
curl -o bsdf/fullwindow.xml
http://www.radiance-online.org/learning/tutorials/fivephasetutorialfiles/fullwindow.xml
I can't speculate what is going wrong with your genBSDF command if you
created these yourself, unless you send me the related input files.
*Subject: *Re: [Radiance-general] Five-phase Method Tutorial: Errors in
generating direct sun coefficient matrix
*Date: *March 20, 2016 1:54:42 PM PDT
Andy,
Thank you for your response. I have migrated to Mac in order to complete
this step of the Five phase method tutorial.
I have pursued the tutorial with the exact scene descriptions and
simulation settings.
I have encountered the following warning/error as follows:
after increasing the limit on the open files in Terminal via the "ulimit
-n 9999" command, I have called the following command as shown in the
tutorial:
Five-phase Method Tutoiral | Example 2 - Rendering | Direct Sun
Coefficient Matrix (page 19) :
command:
$ vwrays -c 4 -pj 1 -fa -vf views/back.vf -x 500 -y 500 | \
rtrace -h- -opn -faa -ab 0 octs/model_nosuns.oct | \
rcontrib `vwrays -vf views/back.vf -x 500 -y 500 -d` -n $procs -fac -fo \
-o viewpics_ds/back_%04d.hdr -e MF:6 -f reinhart.cal -b rbin -bn Nrbins -m
solar \
-c 4 -I -ab 1 -ad 100 -dt 0 -dc 1 -lw 1e-2 octs/model_suns.oct
Warnings:
rcontrib: warning - BSDF "bsdf/fullwindow_t45" has 169.4 front reflection
rcontrib: warning \- BSDF "bsdf/fullwindow\_t45" has 218\.8 rear reflection
Error Description:
Although the given rcontrib warnings do not terminate the command call, it
does not appear to me that any progress is made leaving the command running
for over 24 hours.
Question:
1- What would be the reason for the tensor-tree BSDF file
(fullwindow_t45.xml) generated in the previous steps of the tutorial to
have over 100% reflection as shown in the rcontrib warnings?
2- How can I remedy this problem in this stage of the tutorial to generate
the 5185 direct sun coefficient images?
Best Regards,
Alireza
On Wed, Mar 9, 2016 at 7:25 AM, Andy McNeil <[email protected]> > wrote:
Alireza,
This behavior is consistent with running up against limitations on open
files. I don't know how to change the limit on Windows, but found this:
c++ - Is there a limit on number of open files in Windows - Stack Overflow
Andy
On Mar 9, 2016, at 12:53 AM, Alireza Hashemloo <[email protected]> wrote:
Hi Greg and Rob,
Thank you for your responses:
- It does not appear that the single back quotes are the source of the
problem as I tested the command following your recommendation without
passing the `vwrays -vf views/view_A.vf -x 600 -y 600 -d` to "rcontrib" and
the rtrace "invalid argument" error still appears.
- I have tested the approach to split the command into two parts as you
had suggested:
part 1: vwrays -c 4 -pj 1 -fa -vf views/view_A.vf -x 600 -y 600 |
rtrace -h -opN -fa -ab 0 model_nosuns.oct > points.txt
part 2: rcontrib -x 600 -y 600 -fac -fo -o viewpics_ds/back_%04d.hdr -e
MF:4 -f reinhart.cal -b rbin -bn Nrbins -m solar -c 4 -I -ab 1 -ad 100 -dt
0 -dc 1 -lw 1e-2 model_suns.oct < points.txt
the part 1 appears to work properly considering that a "points.txt" file
is generated. The part 2, however, does not appear to work: although I do
not receive any error messages on my command line, the rcontrib call is
completed immediately after it is run and 508 hdr images are generated in
the given directory. However, each .hdr file is only 1 KB and the attempt
to opening any of them is failed. It does not appear that the files have
actually been written successfully.
In addition, could you elaborate about your suggestion to *" Replace
the "-x 600 -y 600" with the output of "vwrays -vf views/view_A.vf -x 600
-y 600 -d*" " in part 2 of the command?
Finally, I was wondering where the definition for the "solar" modifier
as the target light source passed to the 'rcontrib' call (-m solar) is made
in the previous steps of the tutorial?
Thank you for your help.
Best Regards,
Alireza
On Mon, Mar 7, 2016 at 8:17 AM, Guglielmetti, Robert < >> [email protected]> wrote:
On 3/6/16, 9:53 AM, "Greg Ward" <[email protected]<mailto: >>> [email protected]>> wrote:
I do not think you can have multiple processes under Windows using
rcontrib, no matter which shell you use, so -n 1 (the default) is all you
get.
That is true; rcontrib on Windows will silently ignore -n settings > 1.
On OpenStudio, you will get a heads up about this.
