Hi Rob,
Thank you for your response.
I have checked the orientation of the daylight polygons (exterior window
pane) and it matches the given view direction as 0 -1 0. I changed the view
direction to 0 1 0 just to see if the results would be any different. But I
receive the same daylight matrix file with all values equal to 0.
Would it be convenient for you if I sent you a Google drive link to my
project folder with all the files that you need to run the genklemsamp
command and reproduce the error?
I had also sent a separate post with regards to variations in the commands
for generating all-black models in the next steps of the tutorial.
Thank you,
Alireza
On Tue, Feb 16, 2016 at 7:44 AM, Guglielmetti, Robert < [email protected]> wrote:
At first (quick) glance, my guess is that your window polygon is oriented
backwards. Confirm the window normal faces out, toward the exterior
environment and sky, by looking at the vertex order (right hand rule!).
On 2/15/16, 12:59 AM, "Alireza Hashemloo" <[email protected]<mailto: > [email protected]>> wrote:
I have a question about the Example 2 in the five-phase method tutorial (
http://www.radiance-online.org/learning/tutorials/fivephasetutorialfiles/Tutorial-FivePhaseMethod_v2.pdf
OS: Windows 7 (64-bit)
Command Line Environment: Git Bash
Command:
$ genklemsamp -c 1000 -vd 0 -1 0 objects/glazing_outside_pane.rad | \
rcontrib -c 1000 -ab 2 -ad 1024 -e MF:1 -f reinhart.cal -b rbin -bn Nrbins
-m sky_glow -fa \
model_daylight_matrix.oct > daylight_matrices/daylight_matrix.dmx
Issue: the recorded values in the generated daylight_matirx.dmx are all
equal to 0 (0.000000e+000)
I would appreciate if you could help me with possible causes of the
invalid results.
Thank you,
Alireza
Hi Alireza,
We saw an issue in another model where the windows were very small relative to the wall area, such that genklemsamp was missing them in its initial sampling. The solution is to increase the -c setting (try a factor of 10 more) or using the equivalent rfluxmtx command, which uses a more robust sampling method.
Worth a try....
Subject: Re: [Radiance-general] Five-Phase Method: invalid results in daylight matrix
Date: February 24, 2016 10:25:12 AM PST
Hi Rob,
I have checked the orientation of the daylight polygons (exterior window pane) and it matches the given view direction as 0 -1 0. I changed the view direction to 0 1 0 just to see if the results would be any different. But I receive the same daylight matrix file with all values equal to 0.
Would it be convenient for you if I sent you a Google drive link to my project folder with all the files that you need to run the genklemsamp command and reproduce the error?
I had also sent a separate post with regards to variations in the commands for generating all-black models in the next steps of the tutorial.
Thank you,
Alireza
On Tue, Feb 16, 2016 at 7:44 AM, Guglielmetti, Robert <[email protected]> wrote:
At first (quick) glance, my guess is that your window polygon is oriented backwards. Confirm the window normal faces out, toward the exterior environment and sky, by looking at the vertex order (right hand rule!).
On 2/15/16, 12:59 AM, "Alireza Hashemloo" <[email protected]<mailto:[email protected]>> wrote:
I have a question about the Example 2 in the five-phase method tutorial (http://www.radiance-online.org/learning/tutorials/fivephasetutorialfiles/Tutorial-FivePhaseMethod_v2.pdf\):
Command:
rcontrib -c 1000 -ab 2 -ad 1024 -e MF:1 -f reinhart.cal -b rbin -bn Nrbins -m sky_glow -fa \
Issue: the recorded values in the generated daylight_matirx.dmx are all equal to 0 (0.000000e+000)
I would appreciate if you could help me with possible causes of the invalid results.
Thank you,
Alireza
Thanks Greg!
I will try both approaches.
Alireza
On Wed, Feb 24, 2016 at 10:34 AM, Greg Ward <[email protected]> wrote:
Hi Alireza,
Worth a try....
*Subject: *Re: [Radiance-general] Five-Phase Method: invalid results in
daylight matrix
*Date: *February 24, 2016 10:25:12 AM PST
Hi Rob,
Thank you,
Alireza
On Tue, Feb 16, 2016 at 7:44 AM, Guglielmetti, Robert < > [email protected]> wrote:
On 2/15/16, 12:59 AM, "Alireza Hashemloo" <[email protected]<mailto: >> [email protected]>> wrote:
Command:
invalid results.
Thank you,
Alireza
