< ting-a-ling, ting-a-ling, ting-a-ling-ting-ting >
Ho, ho, ho!
Just in time for the season of slow afternoons and
old TV show reruns I have compiled a preview of my
upcoming Sketchup exporter. This is a test version
and must not be used in a production environment!
Unfortunately it does not work with Internet Explorer
yet so Windows users will find little joy in installing
it. My apologies.
Mac OS X users are advised to upgrade to Sketchup 7 and
grab the zip file from the google code project page:
http://su2rad.googlecode.com/files/su2rad_Xmas_special_2008.zip
I have set up a web page with screen shots and some
comments here:
I will be available on Monday for feedback or help, then
I'll leave for the holidays where I will most likely not
have internet available. I will resume support on the 2nd
of January next year.
So I hope it works for you (and if it doesn't ask yourself
'Have you been naughty ...?' ![:wink: :wink:](https://discourse.radiance-online.org/images/emoji/twitter/wink.png?v=9)
Happy winter solstice celebrations,
Ho, ho, ho!
it. My apologies.
I was able to run it in Firefox on WinXP, fwiw. I didn't have much time to play with it Thomas, but the basics seem to work! thanks Thomas!
I installed SU 7 and put the surad.pl and the su2radlib folder in /Library/Application Support/Google Sketchup 7/Plugins folder.
However, I don't see it in my plugins menu - just Cost > Assign Estimate to Material etc.
I do have it working in SU 5 and SU 6
I also put them in my account Users/robfitzs/Library/Application Support/Google Sketchup 7/Plugins
Could my multiple versions be causing a problem?
OS 10.4.11
Thanks
Rob
From: [email protected] on behalf of Thomas Bleicher
Sent: Sat 1/3/2009 8:32 AM
To: [email protected]; Radiance general discussion
Subject: Re: [Radiance-general] feeling guinea piggish?
Thanks for testing, Rob.
As they say in programming:
It does work - for very small values of 'work'.
But I'm on it! Don't you worry, Windows folks.
And a happy new year, too.
Hi Rob.
That should be a su2rad.rb. Can you check that it
really has the *.rb extension, please. Sketchup will
only load *.rb files. My version of SU7 now came with
are lower case 'plugins' folder. Did you create your
own?
If this is not the problem, open the Ruby console
(menu Window - Ruby console) and type at the prompt
load 'su2rad.rb'
That should, at least, create an error message that
can tell us something. If it returns 'true' it should
be fine.
I don't know is Sketchup uses a private directory.
I'll try that; sounds like a good idea.
OS 10.4.11
Same here. I have no problem with multiple version of
SU. But you can only have one version of 'su2rad.rb' and
'su2radlib' in the 'plugins' folder.
How do you identify your SU versions? I modified
the colors of my appicon to see which is SU7 and SU6.
PS: Good news for the Windows folks: I found the
show stopper bug on IE. Expect an update shortly.
On 6 Jan 2009, at 00:03, Fitzsimmons, Rob wrote:
Thomas,
My typo - it is su2rad.rb - not .pl
I did as you said load `su2rad.rb`
is that a single quote, ' or a back-tic ` (on same key as tilda) ~ ?
I used back-tic ` and got this error
load `su2rad.rb`
Error: #<Errno::EISDIR: /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/: Is a directory - /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/>
(eval):0:in `load'
(eval):0
Thanks
Rob
Sent: Tue 1/6/2009 1:50 AM
Hi Rob.
own?
load 'su2rad.rb'
be fine.
Hi Rob!
Use a single quote, the back-tick on unix systems expands the command
just in a way as it is done in radiance world by adding a ! to the
beginning of an term, so `su2rad.rb` would be replaced by the shell to
the output of the command su2rad.rb - which is the error you got (the
result of that command was 0, so sketchup tried to load a file named 0).
CU Lars.
