Hi guys,
Thank you very much! That was a problem, now it works.
Best wishes!
Urtza.
"Guglielmetti, Robert" <[email protected]> escribió:
Oh yeah, floats are a no go with Windows, at least with this stuff.
Definitely use "-faa" instead of "-faf" when specifying the format...
Hi Urtza,
I think you are right to suspect that you need to change the -m option
parameter sky_glow to sky_mat with the change in your file. Otherwise,
I think your results in "south.dmx" might be missing. What is the size
of this file, and does it contain any data?
It's also untrustworthy to use binary file times under Windows. I would
remove the "-faf" option to rcontrib for that reason.
Subject: Re: [Radiance-general] fatal - unexpected EOF in
header_dctimestep
Date: May 21, 2015 5:21:47 PM GMT+02:00
Hi Robert,
The commands that I used to generate the matrices are:
C:\Radiance\test\TheThree-PhaseMethodSimulatingCFS_A-McNeil\Example1\Viewmatrix>
rcontrib -f klems_full.cal -b kbinS -bn Nkbins -m windowglow -I+ -ab 2
-ad 512 -
lw 2e-5 model_vmx.oct < sensorpoints.pts > results/photocells.vmx
singleclear.xml file I get from WINDOW 7.3
C:\Radiance\test\TheThree-PhaseMethodSimulatingCFS_A-McNeil\Example1\Daylight
Ma
>perl c:/radiance/bin/genklemsamp.pl -vd 0 -1 0 window.rad |
rcontrib -c 100
0 -e MF:4 -f reinhart.cal -b rbin -bn Nrbins -m sky_glow -faf
model_dmx.oct > re
sults/south.dmx
(I do not use in the Sky definition sky_glow name, that is suspicious I
think. I put skyfunc:
void brightfunc skyfunc
2 skybr skybright.cal
3 2 2.29e-001 3.56e-002
skyfunc glow sky_mat
4 1 1 1 0
sky_mat source sky
4 0 0 1 180
skyfunc glow ground_mat
4 1 1 1 0
ground_mat source ground
4 0 0 -1 180
C:\Radiance\test\TheThree-PhaseMethodSimulatingCFS_A-McNeil\Example1\Sky
gensky 12 21 15 | perl c:\Radiance\bin\genskyvec.pl -m 4 -c 1 1 1 >
skies/12_21_15.skv
Do not hesitate to ask me if you need more information.
Thanks!
Urtza.
<[email protected]<mailto:[email protected]>>
escribió:
I may have missed this part, but can you share the commands you used to
generate the matrices?
I am trying to finish The Three-phase Method, but, now I have problems
with dctimestep. I put all files together:
.vmx
.xml
.dmx
.skv
However, fatal - unexpected EOF in header message scripts:
C:\Radiance\test\TheThree-PhaseMethodSimulatingCFS_A-McNeil\Example1\All>dctimes
tep results/photocells.vmx data/singleclear.xml results/south.dmx
skies/12_21_15
.skv | rcalc -e "$1=179*($1*0.265+$2*0.670+$3*0.065)" >
results/illum_122115_cle
ar.dat
Does anyone know what happen?
Thanks in advance!
Kin regards,
Urtza.
[email protected]://www.radiance-online.org/mailman/listinfo/radiance-general
On 5/21/15, 9:49 AM, "Greg Ward" > <[email protected]<mailto:[email protected]>> wrote:
On 5/21/15, 8:02 AM, > "[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>>" <[email protected]<mailto:[email protected]><mailto:[email protected]>><mailto:[email protected]>>> > wrote:
