Hello all!
I'm attempting to customize the falsecolor scale to match the below scale (generated in photosphere) but unable to decipher the options required. Any insights on the -s and -log multipliers necessary? Is there a way to manually set the low end of the scale?
Thanks for your help! So very appreciated!
Kristen
[cid:[email protected]]
systems are scanned for viruses and acceptability of content
Hi Kristen,
If I understand your question, you essentially want to have 6 log divisions with a maximum of 10000 cd/m^2. I think the following will work with falsecolor:
falsecolor -log 6 -s 10000 -i image.hdr > image_fc.hdr
I guess you are not asking about the color scale itself, which should be the same as the default palette in falsecolor. (Running "falsecolor -palettes > pal.hdr" will show you the standard palattes you may choose from.)
Date: August 10, 2017 12:41:57 PM PDT
Hello all!
I’m attempting to customize the falsecolor scale to match the below scale (generated in photosphere) but unable to decipher the options required. Any insights on the –s and –log multipliers necessary? Is there a way to manually set the low end of the scale?
Kristen
^ cool trick, Greg! #alwayssomethingnew #neverends #Radianceisdeep
With the official Radiance version of falsecolor (coded in Perl), there is no way of adjusting the lower end of the scale.
Cheer
Axel
On 10/08/17 20:50, Greg Ward wrote:
Hi Kristen,
*From: *Kristen Garibaldi <[email protected] <mailto:[email protected]>>
*Date: *August 10, 2017 12:41:57 PM PDT
Hello all!
I�m attempting to customize the falsecolor scale to match the below scale (generated in photosphere) but unable to decipher the options required. Any insights on the �s and �log multipliers necessary? Is there a way to manually set the low end of the scale?
Kristen
Full credit to Axel Jacobs on this one -- he thought of this option, came up with the extra palettes, and re-implemented a better version of falsecolor.csh in Perl.
Date: August 10, 2017 12:54:42 PM PDT
While it's true that the minimum is always zero if you are using the default linear scale, setting a log scale allows you to (indirectly) specify the minimum as the scale setting divided by 10^N specified using the "-log N" option. (And "N" can be any positive value.)
I checked, and the setting I recommended works for your example.
Date: August 10, 2017 1:01:01 PM PDT
Cheer
Axel
Hi Kristen,
Hello all!
Kristen
Much appreciated all! Thanks!!!
Kristen
Sent: Thursday, August 10, 2017 4:14 PM
Subject: Re: [Radiance-general] falsecolor scale adjustments
Cheer
Axel
Hi Kristen,
falsecolor -log 6 -s 10000 -i image.hdr > image_fc.hdr I guess you
Cheers, -Greg
Hello all!
Kristen
https://secure-web.cisco.com/1TC63JN9AfCBlgHT2CP4wXjM9J37bm8euY3BsjYncx0umW__H5GAcOrpjnHLq3IJjGlkk-cIKU5AyydJs3T_whrDLv7pgXH845-hzEAwJ1yHUMzg4ovETjQIwpKNsp2uF57eTYTdVHv-rXyAAJdRhOZ68ke40bxDSgotMXJg87cKzzlKYWDfcTNN6WfCl1OqIr2CEo-ljtucFamVYhwxrjxCLwzE9dR6zdyrfzHXFkY98Z5JUe7eseJ8WdiF_v9Nu/https%3A%2F%2Fwww.radiance-online.org%2Fmailman%2Flistinfo%2Fradiance-general
