Hi Axel, hi list,
I just came across a strange behaviour of falsecolor:
the last version of falsecolor.pl (as of January 18) does not show the last
digit of the
lowest value in the legend. I just wanted to get a scale -s 100 -n 10 (i.e.
5, 15, ..., 95)
and here the last line "5" (the only digit in this case) is removed.
I don't work with perl and thus don't really have a clue what's going on.
However,
replacing the lines 280-282
open PSIGN, "| psign -s -.15 -cf 1 1 1 -cb 0 0 0 -h $sheight > $slabpic";
print PSIGN "$text";
close PSIGN;
with the lines as in the version before (v. 2.5)
$cmd = "echo '$text' | psign -s -.15 -cf 1 1 1 -cb 0 0 0";
$cmd .= " -h $sheight > $slabpic";
system $cmd;
solves the problem...
David
Hi David,
Thank you for spotting this bug. It will be fixed in the next HEAD. The bug was caused by a missing new-line in the print statement on line.281:
print PSIGN"$text\n";
It has now been reverted to the older, simpler version which you found in v 2.5, where a system call was used instead.
Cheers
Axel
the last version of falsecolor.pl <http://falsecolor.pl> (as of January
18) does not show the last digit of the
(i.e. 5, 15, ..., 95)
on. However,
open PSIGN,"| psign -s -.15 -cf 1 1 1 -cb 0 0 0 -h $sheight> $slabpic";
print PSIGN"$text";
close PSIGN;
$cmd ="echo'$text' | psign -s -.15 -cf 1 1 1 -cb 0 0 0";
$cmd .=" -h $sheight> $slabpic";
system $cmd;
David
Radiance-dev mailing list
