Hello all,
I've run into a problem with falsecolor on the latest CVS version (compiled this morning). When I try to generate a falsecolor image without a legend (by setting -lw 0 or -lh 0), I get an error: "/tmp/<temp dir>/scol.hdr: bad picture size"
If I try to run the same command on the same image using the official 4R0 release I also have compiled, I do not get this error and the falsecolor image is successfully generated without a legend.
Can anyone else replicate this error? Or is it possible that I have a compiling error somewhere along the way? Any help/insight would be greatly appreciated.
Chris M. Coulter, LC, IESNA, LEED AP
Associate
Lighting Designer
President, Detroit Section of the Illuminating Engineering Society
SmithGroup
500 Griswold, Suite 1700
Detroit, MI 48226
t 313.983.3600 d 313.442.8366 f 313.442.8197
[email protected]<mailto:[email protected]>
Hi Chris,
Thanks for pointing out this error. The falsecolor C-shell script was replaced with a Perl script written by Axel Jacobs, and I guess this particular option wasn't tested. There was a set of single-quotes that needed to be double-quotes, which I have fixed and checked in this morning. It should appear in tomorrow's HEAD.
Date: January 4, 2011 8:01:41 AM PST
Hello all,
I’ve run into a problem with falsecolor on the latest CVS version (compiled this morning). When I try to generate a falsecolor image without a legend (by setting –lw 0 or –lh 0), I get an error: “/tmp/<temp dir>/scol.hdr: bad picture size”
Chris, Greg, all
Sorry about this oversight. Yes, I submitted a Perl replacement of the falsecolor.csh script a couple of months ago. I wrote the Perl script some time ago, needing to run fc on a server that didn't have CSH installed. Well, it seems I did not test all options thoroughly. Apologies for that.
I have since looked at some of the other CSH scripts, and started re-writing some of them. In the long run (Radiance 5.0???), I was hoping to get rid of all of them and replace them with Perl. If there are any 'Perlistas' out there willing to adopt a CSH script and turn it into a Perl one, please get in touch with me. I would not like to burden Greg with this for now. Maybe amongst us, we can come up with a 'coding standard' to have some consistency here. I've got a few ideas and experice with Perl coding (WebHDR is all done in Perl), but it's all a bit rusty...
Axel
