I have just started using this but try using -ip instead of -i and lose the
other parameters. See if it works and keep adding them back one by one see
where the problem is.
On Tue, Feb 24, 2015 at 8:36 AM, Joe Smith <[email protected]> wrote:
just tried this out under Windows and LINUX. Works as it should.
What OS and version of Radiance are you using?
Also, try putting inverted commas around the label string. Maybe your
shell doesn't like the '^' character?
If that still doesn't work, could you try without legend (-lw 0).
On 24 February 2015 at 09:43, Axel Jacobs <[email protected]> wrote:
Hey Joe,
Maybe the falsecolor I'm using is actually "falsecolor2" which use the "-i"
option when specifying an hdr image file ....
Apologize for my late reply!
Joe
On Mon, Mar 2, 2015 at 6:09 PM, Axel Jacobs <[email protected]> wrote:
Has this been resolved, then? What was the issue?
Best
Axel
> Hey Joe,
> Cheers
> Axel
> On 24 February 2015 at 06:36, Joe Smith <[email protected]> > wrote:
>> Dear list,
>> I got the following error when using falsecolor:
>> command:
>> falsecolor -i ./gendaylit.hdr -s 100000 -n 10 -l Wh/m^2 >
>> ./gendaylit_fc.hdr
>> error:
>> Parameters read
>> Creating temporary calculation files..
>> Creating temporary picture files......
>> Rescaling input picture...
>> pcomb -f tmp__\pc0.cal -e v=(y+.5)/yres;vleft=v;vright=v -e
>> vbelow=(y-.5)/yres;vabove=(y+1.5)/yres -x 100 -y 200 >tmp__\scol.pic
>> Creating color contours...
>> Creating picture legend...
>> Combining all parts to the false colored image...
>> 'ra=0;ga=0;ba=0': No such file or directory
>> <stdin>: bad picture size
>> Removing temporary files from ...\tmp__
>> Removing directory ...\tmp__
>> The hdr image to be processed seems fine and can be open in Photomatix
which
>> is shared over here:
>> Dropbox
>> Did I miss anything about the falsecolor program here?
>> Thanks!
>> _______________________________________________
>> Radiance-general mailing list
>> [email protected]
>> http://www.radiance-online.org/mailman/listinfo/radiance-general
Thanks, Joe. The fc image you put up on Dropbox was created with the
old palette, which is available in the latest falsecolor.pl with the
'-pal spec' option. You're using either an older official version, or
falsecolor2 (not sure what the default palette is there).
Dear Axel and Vlad, thank you very much for your suggestions!
Vlad's advice works: change the "-i" option to "-ip", and I got the
following: Dropbox
Joe
Best
Axel
> Hey Joe,
> Cheers
> Axel
> On 24 February 2015 at 06:36, Joe Smith <[email protected]> >> > wrote:
>> Dear list,
>> command:
>> ./gendaylit_fc.hdr
>> error:
>> Parameters read
>> which
>> Dropbox
>> Thanks!
>> [email protected]
