What's up with this?
Randolph M. Fritz, Lighting Design and Simulation
+1 206 659-8617 || [email protected]
It worked for me.
https://github.com/NREL/Radiance/blob/combined/src/util/evalglare.c
Nathaniel
+1 206 659-8617 || [email protected]_______________________________________________
Yeah, whatcha talking about?
To be clear Randolph, the "combined" branch is the one that's kept up to date with the CVS repository. Branch "master" is ancient. As the link Nathaniel posted shows, the combined branch has the evalglare source, and the CMake files include it in the build and package targets:
https://github.com/NREL/Radiance/blob/combined/src/util/CMakeLists.txt#L101-L104
Matter of fact (file under: I love GitHub):
https://github.com/NREL/Radiance/commit/dde95dd17644c0fe8e6849ded9ee48498a5487ba
On 2/8/16, 8:18 PM, "Rob Guglielmetti" <[email protected]<mailto:[email protected]>> wrote:
On Mon, Feb 8, 2016 at 7:03 PM, Randolph M. Fritz <[email protected]<mailto:[email protected]>> wrote:
+1 206 659-8617<tel:%2B1%20206%20659-8617> || [email protected]<mailto:[email protected]>
Oh, I see. I did the regular generic github download and got the wrong
branch.
Why is "master" so far out of date?
the CMake files include it in the build and package targets:https://github.com/NREL/Radiance/blob/combined/src/util/CMakeLists.txt#L101-L104
On 2/8/16, 8:18 PM, "Rob Guglielmetti" <[email protected]<mailto: > [email protected]>> wrote:
On Mon, Feb 8, 2016 at 7:03 PM, Randolph M. Fritz <[email protected] > <mailto:[email protected]>> wrote:
What's up with this?--
[email protected]>_______________________________________________
[email protected]>
http://www.radiance-online.org/mailman/listinfo/radiance-general_______________________________________________
Seems if I follow "git clone https://github.com/NREL/Radiance/" with "git
checkout combined" that does the job. How I would merge my local "combined"
branch with the github respository (should I have changes and the
permission to merge them) I don't understand, but then there's lots of
things about git I don't understand.
(And I suppose we ought to move this discussion to the development list,
bah!)
Randolph
branch.Why is "master" so far out of date?
On Feb 8, 2016 7:46 PM, "Guglielmetti, Robert" < > [email protected]> wrote:To be clear Randolph, the "combined" branch is the one that's kept up to
On 2/8/16, 8:18 PM, "Rob Guglielmetti" <[email protected] >> <mailto:[email protected]>> wrote:
On Mon, Feb 8, 2016 at 7:03 PM, Randolph M. Fritz <[email protected] >> <mailto:[email protected]>> wrote:
[email protected]>
Just remember git is a directed cyclical graph and you'll get pretty
far.... The Atlasssian tutorials are pretty helpful with diagrams and
pictures to go with descriptions of the commands. Here are some docs to
help you:
synching your dev tree
what does rebase do?
Should I merge or rebase?
Stashing changes in git:
https://git-scm.com/book/no-nb/v1/Git-Tools-Stashing
It is hard to give specified advice on how to sync up your environment with
the code line from github without knowing the specifics of everything you
have done locally. But, to answer your questions, assuming you have
un-commited changes on your branch, you *probably* need:
git stash
git fetch
git rebase
git stash pop
If you don't have uncommitted (to your local repository) changes, you can
skip the stash commands and *probably* just do:
git fetch
git rebase
Note the *probably*. This may not be the correct sequence for your
situation.
Good luck!
Tim
On Mon, Feb 8, 2016 at 10:46 PM, Randolph M. Fritz <[email protected]> wrote:
things about git I don't understand.(And I suppose we ought to move this discussion to the development list,
bah!)
RandolphOn Mon, Feb 8, 2016 at 7:55 PM, Randolph M. Fritz <[email protected]> > wrote:
On Feb 8, 2016 7:46 PM, "Guglielmetti, Robert" < >> [email protected]> wrote:To be clear Randolph, the "combined" branch is the one that's kept up to
On 2/8/16, 8:18 PM, "Rob Guglielmetti" <[email protected] >>> <mailto:[email protected]>> wrote:
On Mon, Feb 8, 2016 at 7:03 PM, Randolph M. Fritz <[email protected] >>> <mailto:[email protected]>> wrote:
[email protected]>
Moving over to dev...
The Radiance source mirror on NREL's GitHub site is a dumb, one-way mirror. We use it to make the process of building and hosting Radiance installers, and that's about it. The CVS is still the home of Radiance, and that is where code changes are checked in, generally by Greg and sometimes by Roland now. On the rare occasions I actually do something to the Radiance code, I make my changes to combined and make a diff off that which I send to Greg and he merges into the CVS. Our Git bot updates the mirror hourly, at which time I revert to the last checkout and pull again, and off I go. I do make release tags on GitHib for the packages, but that's about it. Some people have used the Git issues to report, uh, issues, as well. But generally speaking the flow of code is one way, from CVS to Git.
As to why branch "master" is so out of date: master dates to the time when we started the mirror. From the outset the intent was to have a separate branch from which to develop the CMake system, and the Windows version of rvu. The developers responsible for the CMake work set it up this way, and when we moved the mirror crap to NREL we just left it as is. It all Just Works, provided you know about the whole 'combined' branch thing.
Now then, what are you trying to do, Randolph? What changes do you have that you wanted to merge? Again, you wouldn't merge them to NREL/GitHub, they'd need to go to Greg. You could also fork the NREL repo and do whatever you wanted, I suppose.
On 2/8/16, 11:46 PM, "Randolph M. Fritz" <[email protected]<mailto:[email protected]>> wrote:
Seems if I follow "git clone https://github.com/NREL/Radiance/" with "git checkout combined" that does the job. How I would merge my local "combined" branch with the github respository (should I have changes and the permission to merge them) I don't understand, but then there's lots of things about git I don't understand.
(And I suppose we ought to move this discussion to the development list, bah!)
Randolph
On Mon, Feb 8, 2016 at 7:55 PM, Randolph M. Fritz <[email protected]<mailto:[email protected]>> wrote:
Oh, I see. I did the regular generic github download and got the wrong branch.
On Feb 8, 2016 7:46 PM, "Guglielmetti, Robert" <[email protected]<mailto:[email protected]>> wrote:
On 2/8/16, 8:18 PM, "Rob Guglielmetti" <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
On Mon, Feb 8, 2016 at 7:03 PM, Randolph M. Fritz <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
+1 206 659-8617<tel:%2B1%20206%20659-8617><tel:%2B1%20206%20659-8617> || [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>
