Dear Radiance community,
I'm just starting to use Radiance and I'm currently going through the
tutorial. Right at the beginning when trying to view the sphere (page 14)
using the following command "objline objects/things.rad | x11meta", all I
get is a mesh without surfaces and an error saying:
"X connection to /tmp/launch-VcMFzD/org.x:0 broken (explicit kill or
server shutdown)."
When does this error show in the terminal? While you're still looking at
the mesh or only when you close the window? If it only appears after you
closed the window then that's just because the x11meta window does not
terminate the connection to the x server properly. That's not a problem.
Now I'm not sure if the mesh is all that I'm in fact supposed to see at
this stage but I think that this error message is not a good sign.
Any thoughts on what this could mean and how to solve the problem?
It doesn't look like a problem at this stage. Continue with the tutorial
and see if the following steps produce output you expect.
On Wednesday, July 4, 2012, Michael Bannert <[email protected]> wrote:
