Some time ago I compiled epw2wea in Mac... it was done without any consent,
so I have not shared it. I also modified it in order to make an epw2daymtx
program. Are you interested on that program, Rob?
2013/12/16 Guglielmetti, Robert <[email protected]>
WARNING: At least one of the links in the message below goes to an .exe
file,
which could be malicious. To learn how to protect yourself, please go here:
https://commons.lbl.gov/x/_591B
--------Hi Axel,
Epw2wea was forked from the Daysim project and with Christoph Reinhart's
consent was added -- along with proper changes to make and CMake build
files -- to the Radiance cvs. NREL did this because with the addition of
gendaymtx, and its expected weather data input format, we felt it was
almost a necessity for the general Radiance user. If a user grabs any of
the NREL packages, or builds Radiance from source using the makeall script
or standard tools, they will have a copy of epw2wea(.exe) in their Radiance
build.I considered it a bonus that this util was now available to all users, and
that it was deployed as a c program and not another script. On the other
hand, your additions make epw2wea even more useful and I think it makes
sense to replace epw2wea.c with epw2wea.pl. My free opinion. Worth every
penny.Should we go this route, we'd need an update for the skeletal manpage.
Sent: Sunday, December 15, 2013 4:26 PM
To: [email protected]
Subject: [Radiance-dev] epw2wea in Perl--------
file, which could be malicious. To learn how to protect yourself, please go
here:
--------Dear devs,
I have put up a work-in-progress version of epw2wea:
http://www.jaloxa.eu/pickup/epw2wea.exe
http://www.jaloxa.eu/pickup/epw2wea.plThe output is almost identical to the Windows version of epw2wea.exe. I am
not entirely sure where this is from, but it is in the NREL version of
Radiance for Windows.There are three minor differences to the original Windows version:
a) there is a -c (as in 'CSV') option that simply dumps the entire file as
a text spreadsheet with header. The delimiter defaults to ' '
(space), but can selected with the -d option. Please note that if you wish
to have a tab-sep output, then '\t' won't do. Still working out how to do
this. For now, you'll need to give it -c 'CTRL-v TAB' to actually insert a
tab on the command line.I would like to think that a CSV dump of the EPW weather data will make it
a little easier to do a bit of QA on the data. Hence this extra option.b) the 'meridian' bug of the original epw2wea is fixed. Places such as
Delhi (GMT + 5:30 hrs) or Kathmandu (GMT +5:45 hrs) are correctly
represented in the time_zone row of the wea header.c) input can be from STDIN
epw2wea.pl is tested on LINUX and Windows Vista.
Any feedback is very much appreciated. Particularly, I'd love to know your
preferred naming convention for the columns in the CSV output. The
radiation stuff tends to follow CIE conventions. For instance, global
horizontal irradiance is headed as Eeg. I kinda improvised with others, but
tended to be rather verbose with those column headers that I would consider
a little obscure, for the simple reason that I don't tend to use them.
Please do get in touch if there are any other de-facto naming convention
that should be adapted.dev site:
http://www.jaloxa.eu/devel/csh2perl/Good night to you all
Axel
Radiance-dev mailing list
http://www.radiance-online.org/mailman/listinfo/radiance-dev_______________________________________________
Hi Rob,
I've just downloaded the latest HEAD, and found that there is now an epw2wea.c
Well done. When did this happen? This kinda makes my Perl version
superfluous. Might be better to fix the meridian bug (time zones that
are not offset from GMT by a full hour), and forget about the CSV
output. I'ts probably trivial to implement, but my C coding skills are
non-existent.
Best
Axel
On 16 December 2013 18:59, Guglielmetti, Robert <[email protected]> wrote:
WARNING: At least one of the links in the message below goes to an .exe file,
--------Hi Axel,
Epw2wea was forked from the Daysim project and with Christoph Reinhart's consent was added -- along with proper changes to make and CMake build files -- to the Radiance cvs. NREL did this because with the addition of gendaymtx, and its expected weather data input format, we felt it was almost a necessity for the general Radiance user. If a user grabs any of the NREL packages, or builds Radiance from source using the makeall script or standard tools, they will have a copy of epw2wea(.exe) in their Radiance build.
I considered it a bonus that this util was now available to all users, and that it was deployed as a c program and not another script. On the other hand, your additions make epw2wea even more useful and I think it makes sense to replace epw2wea.c with epw2wea.pl. My free opinion. Worth every penny.
WARNING: At least one of the links in the message below goes to an .exe file, which could be malicious. To learn how to protect yourself, please go here:
--------Dear devs,
http://www.jaloxa.eu/pickup/epw2wea.plThe output is almost identical to the Windows version of epw2wea.exe. I am not entirely sure where this is from, but it is in the NREL version of Radiance for Windows.
a) there is a -c (as in 'CSV') option that simply dumps the entire file as a text spreadsheet with header. The delimiter defaults to ' '
(space), but can selected with the -d option. Please note that if you wish to have a tab-sep output, then '\t' won't do. Still working out how to do this. For now, you'll need to give it -c 'CTRL-v TAB' to actually insert a tab on the command line.I would like to think that a CSV dump of the EPW weather data will make it a little easier to do a bit of QA on the data. Hence this extra option.
b) the 'meridian' bug of the original epw2wea is fixed. Places such as Delhi (GMT + 5:30 hrs) or Kathmandu (GMT +5:45 hrs) are correctly represented in the time_zone row of the wea header.
Any feedback is very much appreciated. Particularly, I'd love to know your preferred naming convention for the columns in the CSV output. The radiation stuff tends to follow CIE conventions. For instance, global horizontal irradiance is headed as Eeg. I kinda improvised with others, but tended to be rather verbose with those column headers that I would consider a little obscure, for the simple reason that I don't tend to use them. Please do get in touch if there are any other de-facto naming convention that should be adapted.
dev site:
Axel
Try changing line 74 in epw2wea.c from:
fprintf(WEA_FILE,"time_zone %.0f\n",-15.0*atoi(time_zone));
to:
fprintf(WEA_FILE,"time_zone %.0f\n",-15.0*atof(time_zone));
Does this fix the problem?
Date: December 16, 2013 1:56:58 PM PSTYeah, we have our contract engineer to thank for that; we needed the epw2wea functionality in OpenStudio -- for all platforms -- and he made it happen. Christoph was nice enough to share it in the Radiance trunk a few months ago, so yeah there it is. I would prefer to keep the c version too, the thing is I don't know how to implement your meridian fix either. I can ask our contractor how much of a deal it would be for him to implement it, using your perl version as a template.
Sent: Monday, December 16, 2013 12:48 PM
To: code development
Subject: Re: [Radiance-dev] epw2wea in PerlHi Rob,
I've just downloaded the latest HEAD, and found that there is now an epw2wea.c Well done. When did this happen? This kinda makes my Perl version superfluous. Might be better to fix the meridian bug (time zones that are not offset from GMT by a full hour), and forget about the CSV output. I'ts probably trivial to implement, but my C coding skills are non-existent.
Best
Axel
--------Hi Axel,
--------Dear devs,
dev site:
Axel
Correction: I copied the wrong line. Should be float:
fprintf(WEA_FILE,"time_zone %.2f\n",-15.0*atof(time_zone));
A
On 16/12/13 22:39, Axel Jacobs wrote:
Nearly there. Just to keep the Dalai Lama happy, we need to output with
2 decimal places: 15 / 4 = 3.75fprintf(WEA_FILE,"time_zone %.2f\n",-15.0*atoi(time_zone));
Job done. Thanks, Greg
Regards
Axel
to:
fprintf(WEA_FILE,"time_zone %.0f\n",-15.0*atof(time_zone));Does this fix the problem?
would be for him to implement it, using your perl version as a template.-----Original Message-----
skills are non-existent.Best
Axel
On 16 December 2013 18:59, Guglielmetti, Robert >>> <[email protected]> wrote:
--------Hi Axel,
have a copy of epw2wea(.exe) in their Radiance build.I considered it a bonus that this util was now available to all
epw2wea.pl. My free opinion. Worth every penny.Should we go this route, we'd need an update for the skeletal manpage.
--------Dear devs,
the NREL version of Radiance for Windows.There are three minor differences to the original Windows version:
adapted.dev site:
Axel
Nearly there. Just to keep the Dalai Lama happy, we need to output with 2 decimal places: 15 / 4 = 3.75
Regards
Axel
to:
Best
Axel
--------Hi Axel,
--------Dear devs,
dev site:
Axel
Ah, yes. Didn't notice the sinister "%.0f" in the format. Will check a corrected version into the HEAD release momentarily.
Incidentally, you can see what has been checked in of significance at one central location in CVS:
http://www.radiance-online.org/cgi-bin/viewcvs.cgi/ray/doc/notes/ReleaseNotes
Obviously, you need to scroll to the end, unless you want to read the full change history of Radiance since 1990.
Date: December 16, 2013 2:39:52 PM PSTNearly there. Just to keep the Dalai Lama happy, we need to output with 2 decimal places: 15 / 4 = 3.75
Regards
Axel
to:
Best
Axel
--------Hi Axel,
--------Dear devs,
dev site:
Axel
