Effect of -aa parameter on Rpict Rendering Accuracy
Hello Radiance Community,
The -aa input argument to rpict controls the ambient accuracy of the rendering and approximately represents the error that is associated with it. I ran some tests varying the -aa parameter while holding all other input parameters constant. To my surprise, the execution of a rendering with -aa 0 took 1.6 hours and the a rendering with -aa 0.01 has taken 15 hours and has only finished 28%.
What is considered to be the most accurate rendering? One with no ambient interpolation (-aa 0) or a low error interpolation (-aa 0.01) ?
Overall, what rpict input parameters that will produce the most accurate rendering? Currently, I'm using the following parameter settings, for my "truth" renderings that I'm assuming are as accurate as reasonably possible.
General Parameters: -lr 9 -lw 0.0005 -ps 4 -pt 0.05
Specular Parameters: -ss 2 -st 0 -as 256
Direct Parameters: -dr 3 -dp 1024 -ds 0 -dt 0 -dc 1
Ambient Parameters: -ab 11 -aa 0 -ar 256 -ad 2048
Please let me know if you think I'm missing some important parameters that affect the rendering accuracy.
Thank you for your input,
Andrei Kolomenski
Hi Andrei,
I'd add one more thing to Chris and Greg's comments. When you use a
non-zero -aa value, your ray paths that have gone through differing numbers
of bounces to affect the ambient lighting calculation. Thus, it may not be
a fair comparison to use the same -lr and -lw values for comparing -aa 0 to
-aa 0.01. Instead, you might need to choose a smaller -lw or possibly a
larger -lr for your -aa 0 simulation. I've tested a few scenes where I get
significantly more illumination by using a non-zero -aa value, all other
settings being equal, and I generally believe the non-zero -aa simulations
to give closer results to physically measured values.
Also, perhaps Greg can correct me on this, but I'm not sure if there's
anything to be gained by setting -ab larger than -lr when -lr is positive.
Nathaniel
On Thu, Aug 6, 2015 at 12:24 PM, Greg Ward <gregoryjward@gmail.com> wrote:
Hi Andrei,
Chris has good advice regarding convergence testing, and the appropriate
parameter settings are really dependent on your scene and lighting
conditions. That said, there is a table that discusses various rendering
parameters and is a good place to start. Unfortunately, it is badly in
need of an update:
http://radsite.lbl.gov/radiance/refer/Notes/rpict_options.html
This same out-of-date text file sits in the ray/doc/notes directory of the
standard distribution.
The main thing to be aware of is that changing the -aa setting alone is no
guarantee of overall accuracy, since this parameter *only* controls the
indirect irradiance interpolation accuracy. If the indirect irradiance
values themselves are wrong due to a too-low setting of the -ad parameter
(for example), then improving the interpolation won't help you. This goes
for the other parameters as well. You can think of each as a link in a
chain. It would be great to have an overall accuracy setting, but that
would require a much more basic (and necessarily slower) calculation
method, such as naive Monte Carlo, to work.
*From: *Christopher Rush <Christopher.Rush@arup.com>
*Subject: *Re: [Radiance-general] Effect of -aa parameter on Rpict
Rendering Accuracy
*Date: *August 6, 2015 8:12:46 AM PDT
Someone with better understanding of the math of it might hopefully chime
in, but my understanding has been that the phrase “and approximately
represents the error that is associated with it” – which I think is from
the manual page – may cause some undue concern. Similar to recommendations
for setting the other parameters, if you want test for stable results,
instead of jumping from 0.2 all the way to the extreme 0.01, you might try
0.15, 0.125, 0.1, 0.075 until you don’t notice any difference in your
results from one to the next. I think you mentioned testing various values
for –aa, and what change in results did you see? –aa will sometimes have a
stronger impact on rendering time than it does on your results depending on
the geometric scale of pixels/points you’re trying to discern accurately
from your image.
A second note, if you’re running –aa 0 you probably want –ps 1 and you
want to render an image several times larger than your intended result and
filter it down to reduce noise. I’m not sure of the numerical accuracy of
this technique but I think this is the usual recommendation. If you were
using rtrace for point calculations I suppose the noise introduced in –aa 0
is more visual and should be averaged out in the contributions as measured
at the point (if I’m thinking about it clearly), but maybe not if using
rtrace without the –I parameter?
Hopefully I’m not oversimplifying, and I make my comments hoping someone
will correct my misunderstandings and further expand on it.
-Chris
*From:* Kolomenski, Andrei (JSC-SF311)[WYLE INTEG. SCI. & ENG.] [mailto:
andrei.kolomenski@nasa.gov]
*Sent:* Thursday, August 06, 2015 10:35 AM
*To:* Radiance-general@radiance-online.org
*Subject:* [Radiance-general] Effect of -aa parameter on Rpict Rendering
Accuracy
The –aa input argument to rpict controls the ambient accuracy of the
it. I ran some tests varying the –aa parameter while holding all other
with –aa 0 took 1.6 hours and the a rendering with –aa 0.01 has taken 15
rendering? Currently, I’m using the following parameter settings, for my
“truth” renderings that I’m assuming are as accurate as reasonably possible.
Please let me know if you think I’m missing some important parameters that
Andrei Kolomenski
Yeah, what HE said!
Subject: Re: [Radiance-general] Effect of -aa parameter on Rpict Rendering Accuracy
Date: August 7, 2015 9:05:27 AM PDT
Hi Andrei,
I'd add one more thing to Chris and Greg's comments. When you use a non-zero -aa value, your ray paths that have gone through differing numbers of bounces to affect the ambient lighting calculation. Thus, it may not be a fair comparison to use the same -lr and -lw values for comparing -aa 0 to -aa 0.01. Instead, you might need to choose a smaller -lw or possibly a larger -lr for your -aa 0 simulation. I've tested a few scenes where I get significantly more illumination by using a non-zero -aa value, all other settings being equal, and I generally believe the non-zero -aa simulations to give closer results to physically measured values.
Also, perhaps Greg can correct me on this, but I'm not sure if there's anything to be gained by setting -ab larger than -lr when -lr is positive.
Nathaniel
Hi Andrei,
Chris has good advice regarding convergence testing, and the appropriate parameter settings are really dependent on your scene and lighting conditions. That said, there is a table that discusses various rendering parameters and is a good place to start. Unfortunately, it is badly in need of an update:
This same out-of-date text file sits in the ray/doc/notes directory of the standard distribution.
The main thing to be aware of is that changing the -aa setting alone is no guarantee of overall accuracy, since this parameter *only* controls the indirect irradiance interpolation accuracy. If the indirect irradiance values themselves are wrong due to a too-low setting of the -ad parameter (for example), then improving the interpolation won't help you. This goes for the other parameters as well. You can think of each as a link in a chain. It would be great to have an overall accuracy setting, but that would require a much more basic (and necessarily slower) calculation method, such as naive Monte Carlo, to work.
Date: August 6, 2015 8:12:46 AM PDT
Someone with better understanding of the math of it might hopefully chime in, but my understanding has been that the phrase “and approximately represents the error that is associated with it” – which I think is from the manual page – may cause some undue concern. Similar to recommendations for setting the other parameters, if you want test for stable results, instead of jumping from 0.2 all the way to the extreme 0.01, you might try 0.15, 0.125, 0.1, 0.075 until you don’t notice any difference in your results from one to the next. I think you mentioned testing various values for –aa, and what change in results did you see? –aa will sometimes have a stronger impact on rendering time than it does on your results depending on the geometric scale of pixels/points you’re trying to discern accurately from your image.
A second note, if you’re running –aa 0 you probably want –ps 1 and you want to render an image several times larger than your intended result and filter it down to reduce noise. I’m not sure of the numerical accuracy of this technique but I think this is the usual recommendation. If you were using rtrace for point calculations I suppose the noise introduced in –aa 0 is more visual and should be averaged out in the contributions as measured at the point (if I’m thinking about it clearly), but maybe not if using rtrace without the –I parameter?
Hopefully I’m not oversimplifying, and I make my comments hoping someone will correct my misunderstandings and further expand on it.
-Chris
From: Kolomenski, Andrei (JSC-SF311)[WYLE INTEG. SCI. & ENG.] [mailto:andrei.kolomenski@nasa.gov]
Sent: Thursday, August 06, 2015 10:35 AM
To: Radiance-general@radiance-online.org
Subject: [Radiance-general] Effect of -aa parameter on Rpict Rendering Accuracy
The –aa input argument to rpict controls the ambient accuracy of the rendering and approximately represents the error that is associated with it. I ran some tests varying the –aa parameter while holding all other input parameters constant. To my surprise, the execution of a rendering with –aa 0 took 1.6 hours and the a rendering with –aa 0.01 has taken 15 hours and has only finished 28%.
Overall, what rpict input parameters that will produce the most accurate rendering? Currently, I’m using the following parameter settings, for my “truth” renderings that I’m assuming are as accurate as reasonably possible.
Please let me know if you think I’m missing some important parameters that affect the rendering accuracy.
Andrei Kolomenski
