dxf2rad for win7
  I am searching for a better way to export a .dxf (from Rhino or AutoCAD 2014) file into .rad and saw some post in the radiance blogroll from quite some time ago 2007. The file is split in layers and assembled peaks over 25 MB. Any hint would
  help me alot to save calculation time. Could you, please, give me some idea on what the steps are. Have created also the bat.
  content of bat file :solid.bat dxf2rad \\psf\Home\Downloads\NIYA\#_00_NOW\solid.dxf>\\psf\Home\Downloads\NIYA\#_00_NOW\solid.rad
  when I type in cmd.exe C:\Users\Username>Downloads\NIYA\#_00_NOW\solid.bat
  I get path not found
  Maybe wrong syntax?
  my system is Windows 7.
  Kind Regards, Niya
Hi Niya,
I assume you are using Georg Mischler's "dxf2rad" tool (http://www.schorsch.com/en/download/dxf2rad/). From the instructions:
dxf2rad input.dxf output.rad
So your command would want to look like this (I wouldn't bother with a batch file for this):
dxf2rad solid.dxf solid.rad
Note the lack of a redirect caret (">"), and the use of the filename without the full path. Obviously this means you should run the command from the directory containing your source dxf file. The dxf2rad program should be somewhere on your system's search path for this to work.
Hope this helps!
On 10/8/14, 6:33 AM, "Todor Syarov" <thodor@abv.bg<mailto:thodor@abv.bg>> wrote:
Maybe wrong syntax?
Kind Regards,
Niya
Hi Rob,
  It did not work this way.
  Ive found my syntax error in the batch file so ive managed it with the batch.
  best, Niya
-------- Оригинално писмо --------
От: "Guglielmetti, Robert" Robert.Guglielmetti@nrel.gov
Относно: Re: [Radiance-general] dxf2rad for win7
До: Radiance general discussion
Изпратено на: Сряда, 2014, Октомври 8 22:00:29 EEST
Hi Niya,
I assume you are using Georg Mischler's "dxf2rad" tool ( http://www.schorsch.com/en/download/dxf2rad/). From the instructions:
Hope this helps!
On 10/8/14, 6:33 AM, "Todor Syarov" thodor@abv.bg > wrote:
Maybe wrong syntax?
Kind Regards,
Niya
var m3_u = (location.protocol==‘https:’?‘https://a.abv.bg/www/delivery/ajs.php’:'http://a.abv.bg/www/delivery/ajs.php’); var m3_r = Math.floor(Math.random()*99999999999); if (!document.MAX_used) document.MAX_used = ‘,’; document.write (" ");
