Displaced Results by DAYSIM 3.1b (beta)
Hello all,
  I am using the pipeline Ecotect2011#radiance#daysim3.1
  and still after reimporting the results from Daysim in Ecotect they look as if wanting to be shifted. As far as I know, Ecotect expects the results in a separate file without any coordinates, one value per line and then reassignes the values to the calculation grid on the new sequence in the output file.
  How can I avoid the displacement?
  How do I verify whether the orientation in Ecotect and Daysim are coherent?
  Kind Regrads, Niya
-------- Оригинално писмо --------
От: Thomas Bleicher tbleicher@gmail.com
Относно: Re: [Radiance-daysim] View Daylighting Analysis Results by DAYSIM
3.1b (beta)
До: DAYSIM discussion
Изпратено на: Сряда, 2014, Октомври 1 22:04:38 EEST
   Todor
    I'm not sure about the format of the *.da file but with regards to your second question I think that Ecotect expects the results in a separate file without any coordinates, one value per line. It will then assign the values based to a calculation grid based on the sequence of the values in the results file. I don't have Ecotect around so you should verify this first before you rely on it in your workflow.
On Wed, Oct 1, 2014 at 5:44 AM, Todor Syarov thodor@abv.bg > wrote:
       Dear all,
       I am working on a daylight simulation with pipeline:
       IGDB#optics6#window7.2#ecotect2011#radiance#daysim3.1
       Wanted to correct the suggested lines in the Daysim generated *.da file before feeding back into ecotect.
         Is that the way the edited file should look like?
        # UDI_100-2000 - Static Shading
        # sensor_file_info 0 0 0 0
        8.937460
           3.357410
           0.850000
           53
        7.818620
           3.555310
           0.850000
           51
        10.334970
           3.110880
           0.850000
           68
        12.336220
           6.915090
           0.850000
           57
       Sadly,the sensor points are rotated from Ecotect into Daysim. How do I rotate them back when I return data to Ecotect or is this process automated?
       Kind Regards,
       Niya
Radiance-daysim mailing list
      Radiance-daysim@radiance-online.org
var m3_u = (location.protocol==‘https:’?‘https://a.abv.bg/www/delivery/ajs.php’:'http://a.abv.bg/www/delivery/ajs.php’); var m3_r = Math.floor(Math.random()*99999999999); if (!document.MAX_used) document.MAX_used = ‘,’; document.write (" ");
