direct sampling behavior
Hi Radiance Developers (Greg),
I often find myself oversampling an image by as much as 8 times to render
smooth penumbras. I wonder if it would make sense to add an option to
Radiance that would allow users to force additional direct samples when
they want nice penumbras (assuming that -dj is non-zero). Then when I want
a final image that is 1200x800 I don't need to render it at 9600x6400 and
filter it down, I could render at 1200x800 and request 64 direct samples
per light source to get the same smooth penumbras.
Would this actually help me, or is the time difference between rendering
9600x6400 with 1 direct sample to rendering 1200x800 with 64 direct samples
negligible?
Andy
Dear Picky Penumbra People (Andy):
It's difficult to say for sure without implementing such an option, but the source sampling often dominates the calculation time to the point where you might not gain much over your current approach. Increasing image resolution adds some minor costs for the initial ray casting from the view point, and some calculation time looking up and interpolating values from the ambient cache (assuming you are using that), but those are pretty nominal. Your biggest gains for multiple source sampling would come from scenes with only one or two light sources.
One thing to bear in mind is that lights that are either sphere or source types don't know how to subdivide, so the -ds option doesn't do what it should for those emitters. Otherwise, you can get better penumbras by reducing your -ds value to some small (non-zero) value in addition to using -dj 1.
Subject: [Radiance-dev] direct sampling behavior
Date: September 17, 2015 11:04:22 AM PDT
I often find myself oversampling an image by as much as 8 times to render smooth penumbras. I wonder if it would make sense to add an option to Radiance that would allow users to force additional direct samples when they want nice penumbras (assuming that -dj is non-zero). Then when I want a final image that is 1200x800 I don't need to render it at 9600x6400 and filter it down, I could render at 1200x800 and request 64 direct samples per light source to get the same smooth penumbras.
Would this actually help me, or is the time difference between rendering 9600x6400 with 1 direct sample to rendering 1200x800 with 64 direct samples negligible?
Andy
Could I test the relative speed by rendering a scene with 64 coincident
suns of 1/64th the radiance?
Actually, if this works, it might be a suitable solution for us picky
penumbra people.
Andy
-dj 1.
*Subject: *[Radiance-dev] direct sampling behavior
*Date: *September 17, 2015 11:04:22 AM PDT
negligible?
Andy
Radiance-dev mailing list
Andy,
I think a lot like you. I have a Perl script somewhere around here
that does just that---can't find it yet.
On a related note, I did some experiments a while back comparing
ambient sampling with image oversampling, and in the process learned a
lot about penumbras. I'm posting it here in hopes that you or someone
finds it useful:
http://markjstock.org/radmisc/aa0_ps1_test/final.html
Mark
penumbra people.
Andy
On Thu, Sep 17, 2015 at 12:08 PM, Gregory J. Ward <[email protected]> > wrote:
where
view
using
-dj 1.
want
samples
negligible?
Andy
Mark,
That's great! I didn't expect it, but it's actually quite logical that you
can reduce the -ad parameter when oversampling and when when the ambient
cache is disabled. I guess a pixel in the final rendering is the average of
the oversampled pixels, so 4 ad samples oversampled 4 times is the same as
16 ad samples without oversampling. That should help considerably when
oversampling for penumbras.
Thanks!
Andy
On Thu, Sep 17, 2015 at 12:22 PM, Mark Stock <[email protected]> wrote:
Andy,
finds it useful:
Radiance ambient and penumbra test v2.0
Mark
> penumbra people.
> Andy
> On Thu, Sep 17, 2015 at 12:08 PM, Gregory J. Ward < > [email protected]> > > wrote:
>> where
>> view
from
from
source
>> using
>> -dj 1.
>> Cheers,
>> -Greg
>> *From: *Andy McNeil <[email protected]>
render
>> want
and
>> samples
>> negligible?
>> Andy
>> _______________________________________________
>> [email protected]
Yes, I think the coincident suns trick should work. Did you try it? It's only valid for distant sources -- anything else would give unreliable results, since local sources cast shadows from one another.
-G
Subject: Re: [Radiance-dev] direct sampling behavior
Date: September 17, 2015 12:17:09 PM PDT
Could I test the relative speed by rendering a scene with 64 coincident suns of 1/64th the radiance?
Actually, if this works, it might be a suitable solution for us picky penumbra people.
Andy
Andy
