DF for a polygon
Dear users,
I am calculating DF for a polygon. My approach for this is to use cnt, rcalc and rtrace as described below.
cnt 3000 4351 | rcalc -e 'x=157-$1*0.01; y=168.41-$2*0.01; z=0.85; $1=x; $2=y; $3=z; $4=0; $5=0; $6=1' > grids/grid_level_0.xyz
I then deleted the lines outside my polygon and initiated rtrace.
cat grids/grid_level_0.xyz | rtrace -I -ab 4 -aa 0.05 -ar 128 -ad 512 -as 256 -x 4351 -y 3000 -af ambfiles/df.amb -fac octrees/LSE_DF.oct > images/grid2illum_level_0.pic
which results the following error:
rtrace: fatal - unexpected EOF on input
pfilt: truncated input (y=754)
images/grid2illum_level_0_resized.pic: read error
<stdin>: read error (y==139)
Two of the errors occur when I start to work with the grid2illum_level_0.pic image. If I do not specify the picture size in the rtrace command I get the following error:
pfilt: bad picture size
images/grid2illum_level_0_resized.pic: bad picture size
images/grid2illum_level_0_resized_df.pic: bad picture size
Does this error occur because i delete points in the plane and how do I get around this this?
Best regard
Per Haugaard,
________________________________________________________
Audi, Fiat, Peugeot, Skoda, Porsche, Toyota, Ford - Kelkoo har brugte biler til en hver smag! Klik her for at sammenligne priser.(http://dk.yahoo.com/r/pat/mmb)
Yes, your errors are most likely resulting from deleting some of rtrace
points. Rtrace is expecting 4351*3000 points and is getting fewer, hence
the unexpected end of file error.
From the rtrace manual page: ³If the direction vector is (0,0,0), a bogus
record is printed...² Instead of deleting you could change the vector to
Œ0 0 0¹ and then the area outside of your polygon would be comprised of
bogus records (zeros). This method might not work if you are expecting
legitimate zeros in your output.
On 5/26/09 5:09 AM, "Per Haugaard" <[email protected]> wrote:
Dear users,
following error:
around this this?
Best regard
Per Haugaard,
Trænger du til at se det store billede? Kelkoo giver dig gode tilbud på LCD
TV <http://dk.yahoo.com/r/pat/lcd&gt; !
Hey Andrew,
Thank you for your help. I actually tried that after posting the message yesterday and it worked well. I got daylight factor equal to zero and a nice picture.
I am hoping to illustrate DF=0 with a black color instead of purple. Can I change the puple color (DF=0) to black and how can this be done?
Best regards
Per Haugaard,
Den tirs 26/5/09 skrev Andrew McNeil <[email protected]>:
Fra: Andrew McNeil <[email protected]>
Emne: Re: [Radiance-general] DF for a polygon
Til: [email protected], "Radiance general discussion" <[email protected]>
Dato: tirsdag 26. maj 2009 17.30
Yes, your errors are most likely resulting from deleting some of rtrace points. Rtrace is expecting 4351*3000 points and is getting fewer, hence the unexpected end of file error.
From the rtrace manual page: “If the direction vector is (0,0,0), a bogus record is printed...” Instead of deleting you could change the vector to ‘0 0 0’ and then the area outside of your polygon would be comprised of bogus records (zeros). This method might not work if you are expecting legitimate zeros in your output.
Dear users,
Two of the errors occur when I start to work with the grid2illum_level_0..pic image. If I do not specify the picture size in the rtrace command I get the following error:
Best regard
Per Haugaard,
Trænger du til at se det store billede? Kelkoo giver dig gode tilbud på LCD TV <http://dk.yahoo.com/r/pat/lcd> !
      Find din nye laptop på kelkoo.dk. Se de gode tilbud her - http://dk.yahoo.com/r/pat/mm
Hi Per,
It's a bit non-standard, but you make a duplicate copy of the falsecolor script and customize the new one by altering some lines in there relating to the color scale. Change the line:
  def_redp(i):select(i,0.18848,0.05468174,
to:
  def_redp(i):select(i,0,0.05468174,
Similarly, change:
  def_grnp(i):select(i,0.0009766,2.35501e-05,
to:
  def_grnp(i):select(i,0,2.35501e-05,
and:
  def_blup(i):select(i,0.2666,0.3638662,0.4770437,
to:
  def_blup(i):select(i,0,0.3638662,0.4770437,
I'm thinking this should make the darkest values come out black.
Date: May 27, 2009 12:23:07 AM PDT
Hey Andrew,
Thank you for your help. I actually tried that after posting the message yesterday and it worked well.. I got daylight factor equal to zero and a nice picture.
Best regards
Per Haugaard,
A falsecolor scale that colors zero as black is actually very useful. I
often use pcompos and image masks to achieve the same effect. A second
version of falsecolor modified as you suggested is a major convenience for
me. Thanks!
If others agree that it is useful, maybe it can be incorporated in
falsecolor as an alternate color scale (similar to the -spec option)?
Andy
On 5/27/09 8:37 AM, "Greg Ward" <[email protected]> wrote:
Hi Per,
to:
Similarly, change:
to:
and:
to:
Hey Andrew,
this be done?
Best regards
Per Haugaard,
Hi Andy,
The trouble with such a scale is that it isn't compatible with the -cl and -cb options, since the lines disappear near the bottom end of the scale. That's why I decided against it in the first place.
Date: May 27, 2009 9:51:34 AM PDT
me. Thanks!
Andy
