Thank you, both of you. But I was referring to the IES files from lighting
manufacturers as Greg said. Sorry for not being clear... ies2rad seems to be
exactly what I'm looking for.
Should the following be a new topic?
For something like the following (which is part of a converted IES file, I
think). But regardless, "glow" requires you to specify "red" "green" and
"blue" values. In the following they are equal: 9477... for each.
lamp_glow glow lamp
4 9477.696528 9477.697093 9477.697093 0
So what units are these values in? This ratio of R to G to B shows up in
other parameters too (light, illum). Is there a max value to these RGB
values or for their total? That's one basic thing I've always been confused
about.
Thank you,
Nick
hi
have you crack of IES <Virtual Environment> v5.85 for revit architecture?
could send it to me?
thank
Please refrain from making any illegal requests or exchanges through our mailer, or we will bar you from future communications.
Date: May 23, 2008 6:33:13 AM PDT
hi
thank
Hi Nick,
The glow values (multiplied by whatever pattern is applied) are in units of watts/steradian/sq.meter, or SI radiance. There is no maximum, and values below zero are even permitted in cases where you are outside the standard RGB gamut. You can compute luminance (in cd/m^2) from these values by applying the formula:
Lumiance = 179*(0.2651*Red + 0.6701*Green + 0.0648*Blue)
I hope this helps.
Date: May 22, 2008 11:38:57 AM PDT
Thank you, both of you. But I was referring to the IES files from lighting manufacturers as Greg said. Sorry for not being clear... ies2rad seems to be exactly what I'm looking for.
For something like the following (which is part of a converted IES file, I think). But regardless, "glow" requires you to specify "red" "green" and "blue" values. In the following they are equal: 9477... for each.
lamp_glow glow lamp
So what units are these values in? This ratio of R to G to B shows up in other parameters too (light, illum). Is there a max value to these RGB values or for their total? That's one basic thing I've always been confused about.
Thank you,
Nick
