Defining UP Vector to BSDF Material
hello,
I am trying to use BSDF data generated from photogoniometer reading . while defing the BSDF material in .mat file.
void BSDF m_bsdf_mat
6 0 data.xml ux uy uz func.file
the up vector is to be defined. Can I know what does this up vector mean? how does it influence the surface types. does -t -rz -rx -ry effect the defination. how to define an up vector for a sphere/bubble.?
Thank you
Shashanka Sunkara
Hi Shashanka,
the up-vector relates to some expected orientation of a fenestration system. The more general meaning is that it defines an in-plane reference direction. Since you are probably refering to measured BSDF that is converted by pabopto2bsdf, and since the default expectation for the pgII gonio-photometer is to have the upward direction of fenestration samples point to phi=0, your up-vector should relate to the phi=0 direction. Talking about conventions, typically the outside surface of fenestration samples are measured pointing at theta=0, which conflicts with the idea that the front (surface normal) of the BSDF surface in a Radiance model points inward. You can use the -t switch of pabopto2bsdf to correct for this. For a sphere, please be aware that you will see the spherical surface under angles close to grazing which cannot be included in your measurement. Probably you will have a dark border surrounding the central region of the sphere in your renderings, unless you "fill" / extrapolate the missing directions by e.g. fitting another model to your data. Other than that, if you have a measured BRDF, the up-vector would orient it on the surface as expected.
hello,
Thank you
Shashanka Sunkara
Thank you for you responce. can please ellobrate with an simpel example regardning the effect of up vector.
Shashanka
On 10/04/18 21:00, [email protected] wrote:
Today's Topics:
    1. Fwd: Defining UP Vector to BSDF Material
       (Shashanka Sri Nagaveera Sunkara)
    2. Re: Fwd: Defining UP Vector to BSDF Material (Lars O. Grobe)
Message: 1
Date: Tue, 10 Apr 2018 11:22:05 +0200
  <[email protected]>
Subject: [Radiance-general] Fwd: Defining UP Vector to BSDF Material
Content-Type: text/plain; charset="utf-8"; Format="flowed"
hello,
Thank you
Shashanka Sunkara
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20180410/3c0a327f/attachment-0001.html&gt;
Message: 2
Date: Tue, 10 Apr 2018 13:32:08 +0200
Subject: Re: [Radiance-general] Fwd: Defining UP Vector to BSDF
  Material
Hi Shashanka,
hello,
Thank you
Shashanka Sunkara
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20180410/d5b2afd5/attachment-0001.html&gt;
Subject: Digest Footer
End of Radiance-general Digest, Vol 170, Issue 1
