Defining glazing properties
Full disclosure - I am a newbie working through Rendering With Radiance and having a lot of fun. One question, is it possible to import or define the spectral characteristics of glazing systems in Radiance? For example, if I define a glazing system with Window 7, is there a way to enter those properties in Radiance for daylighting analysis?
Chris Jones
14 Oneida Avenue
Toronto, ON M5J 2E3
416-697-0056
Welcome! As far as I know, you can't export to Radiance from Window, but
you can from Optics. You end up with a simple "glass" definition, and a
front and back material def using the BRTDfunc. Hopefully that's useful to
you. (?)
analysis?
Chris Jones
14 Oneida Avenue
Toronto, ON M5J 2E3
416-697-0056
Yes, that's great. My intro to Radiance was SPOTPro. I am now pursuing the csh shell approach.
I am familiar with Optics although I haven't used it in quite a few years.
I will report back.
you. (?)
>analysis?
>Chris Jones
>14 Oneida Avenue
>Toronto, ON M5J 2E3
>416-697-0056
>_______________________________________________
Chris Jones
14 Oneida Avenue
Toronto, ON M5J 2E3
Tel. 416-697-0056
Hi Chris, Rob,
There is actually a way to extract BSDFs XMLs from Window, but it requires a bit of a roundabout way.
To extract the BSDF XML file from window:
1. Create the window system. Do initial calculation (F9).
2. Enable Radiance calculations (under preferences).
3. Run radiance calculations. This will not work for all materials, some don't have the right information to generate XMLs. If there is an issue saying Radiance is not installed, follow this solution: https://windows.lbl.gov/software/window/7/w7_faq.html#RadianceINI
4. Go to this location C:\Users\Public\LBNL\WINDOW7.3\BSDFs (might be slightly different if you use a different version) to retrieve the XML BSDF file.
5. Use in Radiance as a BSDF file.
Hope this is helpful.
Reinier Zeldenrust
Senior Environmental Designer / Head of Advanced Building Physics
Atelier Ten
Environmental Design Consultants + Building Services Engineers
Message: 2
Date: Fri, 4 Mar 2016 21:54:31 +0000
From: "Guglielmetti, Robert" <Robert.Guglielmetti@nrel.gov>
Subject: Re: [Radiance-general] Defining glazing properties
Message-ID: <D2FF5162.234D6%Robert.Guglielmetti@nrel.gov>
Welcome! As far as I know, you can't export to Radiance from Window, but you can from Optics. You end up with a simple "glass" definition, and a front and back material def using the BRTDfunc. Hopefully that's useful to you. (?)
Chris Jones
14 Oneida Avenue
Toronto, ON M5J 2E3
416-697-0056
Cool, thanks for this summary, Reinier!
On 3/7/16, 2:52 AM, "Reinier Zeldenrust" <reinier.zeldenrust@atelierten.com> wrote:
Hi Chris, Rob,
BSDF file.
Reinier Zeldenrust
Atelier Ten
