dctimestep_Annual results with a sky matrix
Dear experts,
I would like to calculate a Daylight Autonomy by annual data of Three-Phase
Method.
Following the tutorial of McNeil for annual results of illuminance by/
//dctimestep/ command, RGB conversion is not used. I suppose that it is
because it takes a lot of time. If I use RGB conversion as follow:
dctimestep results/photocellsSouthWest.vmx
data/JK_ClearGlass_T70_emis2_0.077_VBlinds.xml results/southwest.dmx
skies/Geneva.smx | rcalc -e "$1=179*($1*0.265+$2*0.670+$3*0.065)" >
results/illum_vb20-smxklemsSW.dat
will I have problems? I would like to manage with sensorpoints x 8760 file.
Thank you in advance.
Kind regards,
Urtza.
Dear Urtza,
If you are working with one of the last Radiance release, you can try the
new command *rmtxop*
*dctimestep....... | rmtxop -fa -c 47.4 119.9 11.6 > illum.dat *
that allows to convert from irradiance to illuminance values, in a matrix
of size #sensors x 8760.
Take a look at the following presentation for more details:
http://www.radiance-online.org/community/workshops/2014-london/presentations/day1/McNeil_BSDFsandPhases.pdf
Giuseppe
2015-07-13 12:32 GMT+02:00 <[email protected]>:
Dear experts,
Three-Phase Method.
*dctimestep* command, RGB conversion is not used. I suppose that it is
Kind regards,
Urtza.
*Giuseppe De Michele*
Dear Giuseppe,
Thank you for your suggestion.
I will check/ rmtxop/ last Radiance release command.
Urtza.
Giuseppe De Michele <[email protected]> escribió:
Dear Urtza,
try
the new command _rmtxop_
   /dctimestep....... | rmtxop -fa -c 47.4 119.9 11.6 > illum.dat /
matrix of size #sensors x 8760.
   Giuseppe
_Dear experts,
Three-Phase Method.
file.
Kind regards,
Urtza.
_
________________________________________________
http://www.radiance-online.org/mailman/listinfo/radiance-general_
_-- _
   _/Giuseppe De Michele/_
Dear Giuseppe,
I am trying with "rmtxop" with Windows OS and it scripts:
C:\Users\Urtza\Desktop\IEA50\CFS>dctimestep
review/results/photocellsSouthWest.vmx
data/JK_ClearGlass_T70_emis2_0.077_VBlinds.xml review/results/southwest.dmx
review/skies/Geneva.smx | rmtxop -fa -c 47.4 119.9 11.6 >
review/results/illum_vb20-smxklemsSWrgb.dat
Usage: rmtxop [-v][-f[adfc][-t][-s sf .. | -c ce ..] m1 [+] .. > mres
Do you know what happen? Thank you in advance.
Best regards,
Urtza.
[email protected] escribió:
Dear Giuseppe,
I will check /rmtxop/ last Radiance release command.
Urtza.
Dear Urtza,
try the new command _rmtxop_
illum.dat /
    Giuseppe
_Dear experts,
Three-Phase Method.
file.
Kind regards,
Urtza.
_
_--_
You need a final '-' for rmtxop to read from its standard input.
Subject: Re: [Radiance-general] dctimestep_Annual results with a sky matrix
Date: July 16, 2015 1:18:04 AM PDT
Dear Giuseppe,
C:\Users\Urtza\Desktop\IEA50\CFS>dctimestep review/results/photocellsSouthWest.vmx data/JK_ClearGlass_T70_emis2_0.077_VBlinds.xml review/results/southwest.dmx review/skies/Geneva.smx | rmtxop -fa -c 47.4 119.9 11.6 > review/results/illum_vb20-smxklemsSWrgb.dat
Best regards,
Urtza.
Dear Giuseppe,
I will check rmtxop last Radiance release command.
Urtza.
Dear Urtza,
If you are working with one of the last Radiance release, you can try the new command rmtxop
that allows to convert from irradiance to illuminance values, in a matrix of size #sensors x 8760.
Giuseppe
Dear experts,
I would like to calculate a Daylight Autonomy by annual data of Three-Phase Method.
Following the tutorial of McNeil for annual results of illuminance by dctimestep command, RGB conversion is not used. I suppose that it is because it takes a lot of time. If I use RGB conversion as follow:
dctimestep results/photocellsSouthWest.vmx data/JK_ClearGlass_T70_emis2_0.077_VBlinds.xml results/southwest.dmx skies/Geneva.smx | rcalc -e "$1=179*($1*0.265+$2*0.670+$3*0.065)" > results/illum_vb20-smxklemsSW.dat
Kind regards,
Urtza.
Thank you very much Greg. Now it works.
Best regards,
Urtza.
   SUBJECT: Re: [Radiance-general] dctimestep_Annual results with a sky
matrix
   DATE: July 16, 2015 1:18:04 AM PDT
  Dear Giuseppe,
Best regards,
Urtza.
Dear Giuseppe,
Urtza.
Dear Urtza,
illum.dat /
    Giuseppe
_Dear experts,
Three-Phase Method.
file.
Kind regards,
Urtza._
